Old 06-28-2009, 02:40 PM   #1
Steering column & turn signal help
My turn signals stopped canceling themselves after making turns a couple weeks ago.
I took off the steering wheel today to take a look, and found some plastic bits floating around the steering column. I'm attaching photos of the parts, and the control stalk assembly in case someone can help me identify where they are from and what I need to replace.
I forgot to put anything in the photo for scale, but the larger piece of plastic is similar in size to a US dime.
-james
'01 Boxster S, 51k miles
yimmy149 is offline   Reply With Quote
Old 06-28-2009, 06:17 PM   #2
Lil bastard's Avatar
The bits are the turn indicator canceling mechanism. Clearly, this is why it no longer functions.
The entire assembly must be replaced as the parts are not available separately, so you cannot repair it. That means new wiper/turn indicator/cruise control stalks along with the center piece and electrical connectors. The stalk covers will not be included and will have to be either purchased separately or swapped from the existing unit.
If you don't have the OBC function w/ 4th stalk, now would be a good time to consider the upgrade.
Contact Sunset for the best new prices of try to find the unit at any of the reputable wreckers: LA Porsche, Oklahoma Foreign, etc.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 06-29-2009, 05:16 PM   #3
Thanks.
I took a look at the guides for the OBC, doesn't sound to bad. I don't really want/need it, but it's only $40 more for the part that includes it. My biggest concern is damaging the gauge cluster or wiring harness while wiring it up. Is that likely?
Another question, one of the grounds (?) from the clockspring to the steering wheel broke. It would probably be easy for me to repair - but I'm wondering if I should just replace the whole spring ($150) while I'm in there. Do they fail often on these cars?
-james
Old 06-29-2009, 07:02 PM   #4
The assembly w/ 4th stalk is $40 more, but you do need to spend about $10 more to buy the necessary molex connectors and wiring to make up the harness, also, you need to have the OBC turned on (already to go if you currently can display outside temp). Some dealers will do it for free while others charge to do it.
Not to worry about the gauge or cluster, it's a simple hack.
Not understanding what you mean by the ground on the clockspring, but if you mean the 2 plastic posts I would replace it. It is part of the airbag system - the contact spring to be precise.
1976 BMW 2002
1990 BMW 325is
Old 07-04-2009, 10:46 AM   #5
Just a little update - I received the new contact spring and control stalk assemblies yesterday. The broken pieces I posted - they are part of the contact spring. I'm guessing the turn signal would continue functioning if I reused it - I think the parts were interfering with it's operation.
-james
Old 07-05-2009, 10:02 AM   #6
I read this post the other day.
And, now my turn signals lost their "cancel". Thank you very much...its all your fault yimmy!
fatmike is offline   Reply With Quote
Old 07-06-2009, 11:22 AM   #7
Same Problem
If you do a step by step guide, I'll buy you a beer next time you're in San Francisco. What a pain. I also have a strange clicking noise (probably parts rattling around) while making right turns coming from the steering column.
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
Oaktown 986 is offline   Reply With Quote
Old 07-06-2009, 11:30 AM   #8
07 Carrera S Cab
Boxtaboy's Avatar
Here's the DIY how to. I'll take that beer.
http://www.whiteson.org/boxster/mods/obc/obc.stalk.pdf
http://www.renntech.org/forums/index.php?act=Print&client=printer&f=2&t=13025
Old 07-06-2009, 02:01 PM   #9
No, you don't need security bits. Maybe you'll do fine with a torx driver, I just couldn't get mine to budge, and was worried about damaging the screw since I was working at a slight angle due to the length of the driver.
The holes in the back of the steering wheel are narrow and almost 2" deep. The torx socket sets I looked at seemed too wide to fit in the hole.
I followed the procedures in the Bentley manual. I'm still waiting on a couple VW wires to do the OBC hack, so I haven't re-assembled yet, but so far so good. The main things that might not be completely obvious: Disconnect the battery a wait a few minutes so you don't trip any airbag wiring faults. Store the airbag padded side up. Center the wheels and mark the steering wheel & column with white out or a center punch so you put it on straight.
-james
Old 07-06-2009, 02:07 PM   #10
07 Carrera S Cab
Boxtaboy's Avatar
-james
Good tips. Thx.
Old 07-09-2009, 09:36 AM   #11
I was staring at the parts while eating my cheerios this morning and realized I didn't fully understand what Lil Bastard was saying. The larger tab that broke off my contact spring is what cancels the turn signals - I didn't grasp that as somewhere else I had read there was an eccentric on the steering column that did it.
I've verified that my old stalks cancel just fine, and even the little nub is in good condition. I guess I can sell those used.
Still waiting on the VW dealer for the OBC hack wiring.
-james
