Old 06-24-2009, 06:42 PM   #1
Question shaken steering wheel
The point is my good friends ,every time that I'm going from 73 mph-about 80mph my steering wheel start shaken not that bad, but I don't like it any suggestion please, My car Boxster 2001 base.Thanks for any help as always.
andre69 is offline   Reply With Quote
Old 06-24-2009, 06:54 PM   #2
tonycarreon's Avatar
check tire pressure. my box shook for a few weeks until i checked the tire pressure and realized the passenger side was about 6 psi > the driver side. after setting them to the same pressure it stopped.
granted mine shook from ~40 mph - 50 mph.
Old 06-24-2009, 10:55 PM   #3
Could be many things, but the first thing that comes to mind when you say this, is wheel/tire balancing.
Perhaps look into getting all of your wheels/tires rebalanced, or even Roadforce balanced on a Hunter machine...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 06-25-2009, 03:50 AM   #4
You may also want to check the torque on the lug nuts. Believe it or not it greatlyeffects vibtation. Ed
cvhs18472 is offline   Reply With Quote
Old 06-25-2009, 08:02 AM   #5
I have also read that the weights used to balance the wheels (they're affixed behind the spokes) can fall off...
Most likely culprit IMO is tire balance or tire wear.
1999 Carrera 4 • Aero kit • 4" UD Pulley
My Corvette doesn't leak oil... it sweats horsepower.
sd_boxster is offline   Reply With Quote
Old 06-25-2009, 08:09 AM   #6
check these in order - stop when problem goes away
1) Tire pressures to factory specs
2) Inspect front tires - any uneven wear?
3) Torque lug bolts to factory specs
4) Get 4 wheel tire balance
5) Inspect tie rod ends for looseness/wear
6) Inspect front suspension bushings for wear
7) Inspect McPherson strut top mounts for looseness
8) 4 wheel alignment
9) Replace tires
10) Replace wheels
11) Get another car
renzop is offline   Reply With Quote
