Old 04-21-2009, 09:41 AM   #1
Help needed with rear suspension
OK, so I had the dreaded rear suspension clunk, worse on the passenger side than driver's side. Last December I had both rear lower control arms replaced by te dealership. Slight improvement, but the clunk was still there going over rough pavement and sharp bumps.
A couple weekends ago I replaced the rear track arms with debluzparts (sp?) adjustable rear track arms. Clunk is now almost nonexistent on the driver's side, but the passenger side now has more of a metal on metal sound when driving over rough pavement and sharp bumps. It even makes a slight sound when braking hard and coming to a stop, as if something is sliding back and forth. I've checked and everything is bolted tight.
Any suggestions on where to look next? This issue is driving me NUTS!
shaman1204 is offline   Reply With Quote
Old 04-21-2009, 02:53 PM   #2
Make sure the nuts are tight on both ends of the drop links to the sway bar.
Sammy is offline   Reply With Quote
Old 04-21-2009, 03:11 PM   #3
Track rat
Topless's Avatar
Sounds a little like a loose bowling ball in your trunk? Possibly a worn out front motor mount. Give it a look.
Old 04-21-2009, 03:28 PM   #4
Another thing to check is the three bolts on the top of the strut and the center nut as well. Access is done with the top in service position and the foam pulled back. You'll see it.
Old 04-21-2009, 03:43 PM   #5
Great, thanks for the advice everyone.
Topless, is there an easy way to check the motor mount? Is it a visual inspection like looking for a torn bushing or something?
And Randall, I will check the strut bolts as well. If Sammy happens to be correct on the drop links, I came across a posting of yours where you mentioned you replaced yours in about 15 minutes per wheel. So this is a pretty easy DIY?
I am bound and determined to have a "quiet" car soon! :troll:
Old 04-21-2009, 04:00 PM   #6
Lil bastard's Avatar
Be careful with the strut nuts! The torque spec is only 24 ft.lbs. and they are very easy to snap off - be sure to use a torque wrench. Also, never loosen more than 1 at a time or you risk losing your camber setting.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 04-21-2009, 04:10 PM   #7
LB makes a great point. Don't get too enthusiastic. When my strut bolts were loose, I could see there was a 1/16th of an inch gap between the nut and the bodywork.
Drop links are really easy to change. I bought Deutche Products ones from eBay but another forum member said his didn't hold up a year before the rubber cracked on him so do your research and replace them with quality parts.
Old 04-21-2009, 06:21 PM   #8
OK, I'll grab the torque wrench for the strut bolts. I have to clean my MAF soon anyway.
Without going out and crawling around on the cold, wet ground right now, anyone happen to have an exploded diagram of the drop links location? I looked in the Boxster parts diagram but couldn't find it. Thanks.
Old 04-22-2009, 05:10 AM   #9
Exclamation You guys lose me with the abbreviations/acronims
OK what is a MAF? Is there a glossery for all these TLAs? Where is a "Boxster parts diagram"?
ChefCarnivore is offline   Reply With Quote
Old 04-22-2009, 06:44 AM   #10
1) MAF (Mass Air Flow Sensor)
2) check out www.********************************************.com for excellent parts diagrams on the boxster
jjanari is offline   Reply With Quote
Old 04-22-2009, 07:42 AM   #11
Track rat
Topless's Avatar
It is difficult to see without removal. You can open the inspection hatch behind the seats and get in there with a strong light and a mirror. Or start the motor and rev a little and you can see the motor flopping around with engine torque. Here is a good DIY for more info:
http://www.pedrosgarage.com/Site%203/Install%20Front%20Engine%20Mount.html
Old 04-22-2009, 07:50 AM   #12
If you pull off one rim you'll see it right in front of you. If it were any easier to locate, it would bite you on the nose.
Buy four of them and get the two wrenches you'll need for installation (can't remember the sizes off hand) and git-r-done.
If your car is five or six years old or older, you probably need them so get them and replace them one afternoon.
If I can do it, ANYONE can do it. Trust me.
Old 04-22-2009, 07:14 PM   #13
Got it. Supposed to be 80 and sunny this weekend, so I'm checking things tomorrow or Friday and I'll update on what I found.
Old 05-29-2009, 02:41 PM   #14
No dice on suspension rear noise...
Well, finally got around to checking the strut bolts and all were good and tight. Replaced the drop links and it had no change in the noise. So, I'm now suspecting its the struts themselves. It's hard to believe they would be shot at 40k miles, but who knows.
Any other ideas, short of replacing the entire suspension? To date I have replaced the rear lower control arms, rear track arms and drop links. If I seriously have to put a lot more money into the suspension to quiet it, the line to trade the thing in is growing closer.
Old 05-29-2009, 09:19 PM   #15
Brad Roberts's Avatar
Rear shock mounts are blown out. Did *somebody* happen to install new shocks not too long ago? I'm not familiar with your car.
To check the engine mount..place a long prybar between the body mount and the engine mount. Lift or pull down depending on how you place the prybar. 99% of every street car I look at it BROKEN. Porsche knew there was a problem with them and changed the design for the later Boxsters and Caymans.
Mount as it is on your engine under the car:
BLOWN OUT Mount..
How it ALL begins...
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
Old 05-30-2009, 08:49 AM   #16
[QUOTE=Brad Roberts]Rear shock mounts are blown out. Did *somebody* happen to install new shocks not too long ago? I'm not familiar with your car.
No one installed new shocks that I know of, they look original. I will have to check the motor mount as you suggested. Thanks for the input.
Old 06-08-2009, 03:04 PM   #17
Only one other place left to check..the motor mount.
kamran66 is offline   Reply With Quote
