Old 04-20-2009, 12:52 PM   #1
Clutch Replacement: what performance mods to do?
48k miles on the car...original clutch.
I've had a second RMS or IMS leak (first was covered under warranty....porsche is saying they're only going to pay 1/2 of parts and labor...I'm not pleased about that...seems they should cover it all since they didn't fix it right the first time...'there's an updated seal that will fit it'....ya right)
anyhow, if I have the transmission down, I'll likely update the clutch since it's probably only got another 10k miles in it)...so, what performance mods should I consider doing while they're in there?
01 S - gone
FUHRIUS is offline   Reply With Quote
Old 04-20-2009, 01:33 PM   #2
I would take a look at your IMS bearing to determine if you have a single or double. If single, you can update to the newer style without taking the engine apart. If you've not read up on this, please refer to this:
http://www.lnengineering.com/ims.html
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 04-21-2009, 12:00 PM   #3
You might want to think about a limited slip differential.
2000 Boxster S
http://www.slipangle.com/images/ACSpeed_sig.jpg
heyjae is offline   Reply With Quote
Old 04-21-2009, 05:59 PM   #4
Please post more about the LSD. How much are they? Where do you get one? How much is instaling expected to cost? Is it really noticeable for a car that is not tracked, but drivin hard for fun?
2002 S
Old 04-21-2009, 06:07 PM   #5
What about a lightened flywheel?
I did that on two priors cars I owned when they had clutch work - one was a mazda RX7, the other a miata.
on each car - it made the car much more responsive and quicker. you reduce the weight of the flywheel, requireing less inertia to spin it. i believe it's the same logic that makes an underdrive pulley make power - there is less drag on the mtoor - less power is drawn to spin the flywheel - so more of it gets to the ground. it doesn't "create" horespower, it just frees up some that is already there being wasted.
my cars felt quicker shifting, and also felt to run through the rpms faster. overall it made m y rx8 and miata feel noticeably more responsive and faster.
no idea if people would recommend it on the boxster - or how much it costs - but i would certainly look into it. i plan to when i do my clutch.
i have 75k on the original clutch!
23109VC is offline   Reply With Quote
Old 04-21-2009, 07:24 PM   #6
talk with "insite" for recomendations on light flywheel. It is not simply bolt on and go. You currently have a dual flywheel and you want to switch to a single mass wheel. There are problems associated with that such as chatter and IIRC Mr. Raby commented on the harmonic imbalance of a single mass wheel leading to vibrations and ultimatly catastrophic engine failure.
2002 S
