Old 04-18-2009, 11:28 AM   #1
CEL 1128 & 1130
Hello Everyone
A few days ago my Check Engine Light came on, I stopped driving it, and today I took it over to Autozone and they read the codes for me, 1128 & 1130, the code reader did not recognize that it was a Porsche, but I'm sure thats normal.
Today the car drove perfectly fine, HOWEVER I do hear a "hiss".
Any help, guidance or other experiences with these codes would be greatly appreciated.
Joshua
New Orleans
2001 Boxster
2014 Toyota Tundra
"Its Craptacular" - Bart Simpson 1997
joshua6060 is offline   Reply With Quote
Old 04-18-2009, 11:46 AM   #2
1128 - oxygen sensing, area 2 cylinders 1 - 3 - short to B+ - rich mixture threshhold
1130 - same, but cylinders 4 - 6
simultaneous onset would be suspicious. It would seem reasonable that there is a common cause.
brp987 is offline   Reply With Quote
Old 04-18-2009, 11:46 AM   #3
I don't inow about those exact codes - but my car threw a check engine light and was hissing. it was a vacuum leak.
after i got it fixed and drove it a few hours - it drove much better. i had thought my car was losing power - after the vacuum leak was fixed - it ran much better.
there was a noticeable gaini n hp/torque after the leak was fixed.
my hissing noise sounde like an inner tube with a leak and then you rubbed water on it - that hissing/bubbling sound... at least that is how it sounded. total cost to repair at an indpenenent - parts/labor - $250.
hope that's what is it as it was a cheap/quick fix!
23109VC is offline   Reply With Quote
Old 04-19-2009, 08:42 AM   #4
Track rat
Topless's Avatar
Your car is running lean and the DME is compensating but has reached it's rich threshold.
Possible causes:
**Intake air leak** (hissing sound)
Failed AOS
Bad gas cap/ oil fill cap
Bad MAF
