Old 03-23-2009, 06:45 PM   #1
Has anyone had a leak at the rear of the oil sump cover?
I've been puttering through spring maintenance on my 1999 2.5L for the last few weeks, and just noticed what appears to be an oil leak at the rear of the oil sump cover gasket. After a pretty thorough cleaning, I've convinced myself that its not coming from the oil drain, and I don't see where else it could have originated from.
Has anyone had a problem with a leak in this gasket? Wanted to see if anyone had a 'Yeah, I thought it was that and then..." story.
Also, I don't see this referenced in Bentley other than that the cover exists in the oil section. Is this one of those unique situations where these bolts hold the cases together or something equally traumatic?
-Thanks.
machone is offline   Reply With Quote
Old 03-23-2009, 08:32 PM   #2
Lil bastard's Avatar
Could be RMS, hope not.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 03-24-2009, 04:19 AM   #3
RMS was one of my first thoughts
That was one of my first thoughts, but I believe that it would be leaking between the cases (i.e. down the back of the engine) if that were the case. (Please correct me if I'm wrong.) Doesn't appear to be occurring, the gasket of the oil sump cover appears to be wet.
Found an exploded diagram of the sump, it doesn't appear that the cover is anything more than a cover. Also looks like there isn't a service gasket for it, just use silicon. That surprised me, because I thought I could see a steel core gasket peeking out.
Old 03-24-2009, 04:37 AM   #4
can you post a picture? I have a really small leak on one of the bolts on my oil return pump. It's a common thing. I posted a few pics of mine several months back. If I can find it again I'll post the link.
-SP
2001 Boxster S
Desnorkled
Pioneer Avic D3
JL Audio 6.5 inch subs (in the door)
Pyramid 4 channel amp
chitowndad is offline   Reply With Quote
Old 03-26-2009, 04:03 AM   #5
Took a day to get back out for a photo
Unfortunately I don't get to work on it every evening
Here's a photo looking towards the front of the motor.
Had a friend look up the recommended procedure in a commercial service database, appears that its a pretty straightforward R&R, with a permatex-type gasket recommended.
-SP
