Old 03-19-2009, 10:36 AM   #21
Markzeronine,
To answer your question: Which 986 lowering springs go the lowest?
Answer: (From Lowest drop, to mildest)
1: Eibach (lowest)
2: Gemballa/H&R(same springs-id go for the cheaper one)
3: Intrax
4: ROW M030(mildest- doesn't need camber toe links/kits)
I dont have the exact degree of drop, but use this as your guide for further research. There's tons of info. out there.
spine911 is offline   Reply With Quote
Old 03-19-2009, 11:08 AM   #22
[QUOTE=RandallNeighbour]If you do lower the car with springs alone, get ready for accelerated rear tire wear if you don't buy some adjustable toe links to put in the back to correct the additional camber lowering the car will do to the suspension....QUOTE]
I didn't buy the adjustable toe links, and yes, the chamber is a bit off, but looks and drives fine....very close to spec, not too concern about tire wear, drive less than 6K per year and been trying to get rid of the current set I have for a couple of years
I also bought my Gemballa springs on Ebay auction for $250....so keep an eye there for good deals.
Last, even with this low cost in springs, and some DIY, I did the fronts, $300 for the rear, I paid out close to $1000, so it's not a cheap upgrade.
Springs - $250
Tools - $100
Rear Install - $300
Alightment - $200
-Cesar
03' 986 Midnight Blue Metallic
_____________________________________________
Gemballa Lowering Springs | 18” Carrera Light Wheels | Painted Calipers
14/18 H&R Spacers | Aero Wing & Rockers | Powder Coated Exhaust
Creator of CRIOS exhaust mod | De-Snorkeled | De-Ambered
Light Weight Flywheel | Tinted Windows and Windscreen
Painted Bumperettes | 550 Spyder Grille Kit
http://lh5.ggpht.com/_9sTq_sN1KDw/Si...2009%20055.jpg
crios is offline   Reply With Quote
Old 03-19-2009, 12:41 PM   #23
Thanks guys.. I work at a Porsche shop so I installation and alignments won't be a problem. I just wanted to get a general idea of which go lowest strictly on a visual basis. I have the knowledge to figure out what else I want out of them
It looks like I'm getting Ed's H&R's so I'll be good with those for a while.
Don't let that stop the pics of lowered boxsters though, I love them
markzeronine is offline   Reply With Quote
Old 04-03-2009, 10:38 AM   #24
just an FYI - check your Ksports for leaking. I had a set on my Subaru two years ago and ended up having what I thought was poor build quality. I had to rebuilt 3 in 1 year due to leaking. One of them twice.
I chucked them and went for someone else brand and so far so good.
I was all ready to buy lowering springs and then decided to throw another $500 at the car and put Ksport Kontrol coilovers on. The car rides as if it's on rails now. No noticeable body roll like before.
It was worth the extra money.
eVoMotion is offline   Reply With Quote
Old 04-03-2009, 12:26 PM   #25
I just put on a complete ROW MO30 kit on my 98 base. It lowered about 1" and looks much better. The handling is unbelieavable. I picked up the shocks, springs, sway bars and bushings for $1023.00 delivered which was actually the cheapest upgrade available and it was engineered by Porsche for my car. I'm happy. Ed
cvhs18472 is offline   Reply With Quote
Old 04-04-2009, 02:45 PM   #26
Thanks for the warning. I'll yank my wheels and inspect them.
Old 04-09-2009, 01:14 PM   #27
here are the H&R's I chose
