Old 03-16-2009, 10:05 AM   #1
HELP! Horn fuse costs and DIY
Dear Enthusiast - the horn on my 99 boxster is out. It was going off on its own and I realize I have to replace the horn bracket (I believe it costs like $65 on PelicanParts). But I need some info about the locating the fuse and the cost of replacing it.
Please advise and thanks in advance.
-lejolierogue
le jolie rogue
lejolierogue is offline   Reply With Quote
Old 03-16-2009, 10:45 AM   #2
the horn fuse is B3 - there is also a relay though...
Old 03-16-2009, 09:05 PM   #3
You can get it for less at Suncoast:
http://e-partssales.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=airbagframe&Category_Code=POTEBXCC
It's really easy to change:
1. Disconnect battery
2. Remove 2 torx screws from the backside of the steering wheel (behind airbag)
3. unplug airbag and set aside.
4. Remove 4 small bolts holding on the retainer frame
5. Install new frame.
6. Reinstall airbag and screws
7. Re-connect battery
8. ENJOY!
releese78 is offline   Reply With Quote
Old 02-02-2010, 07:01 AM   #4
97 Boxster's Avatar
Thanks so much for this information. I have a horn that works when I plug the fuse in it goes off constantly. Now I will order this part and replace the bracket. Looking forward to getting this done.
97 Boxster is offline   Reply With Quote
Old 02-09-2010, 10:17 AM   #5
97 Boxster's Avatar
I guess that I also have to be concerned about disconnecting the battery and my radio codes as well. Correct?? Do you have to reprogram your radio once you hook the battery back up?
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
Old 02-09-2010, 12:13 PM   #6
Depends on model year is the answer but in your case w/ a '97, yes you need to input the code for your radio after reconnecting the battery. Post '03 MY, Porsche uses the MOST fiber optic system which no longer required the radio code.
Old 05-09-2010, 06:30 AM   #7
Horn malfunction
I am having the same issue where the horn works but it goes off constantly when I put the fuse in. If I push the front of the steering wheel the horn stops. Below Releese 78 mentions the retainer frame. I have the airbag off removed from the car. Where is the retainer frame located? I looked at the Suncoast web site linked below and I could not find the part that Releese 78 is referring to and part of the reason I cannot find the part because I am not totally sure what I am looking for. Thanks in advance for your help.
Nick 986 is offline   Reply With Quote
