-   -   coolant / antifreeze question... (http://986forum.com/forums/boxster-general-discussions/19852-coolant-antifreeze-question.html)
mikes_box 03-10-2009 01:15 PM
read the forum on changing/flushing the coolant but i've been looking everywhere for the brand that was recommended... cant seem to find zerex g-05. only one i keep seeking is prestone, or peak.. any help would be great...
husker boxster 03-10-2009 02:01 PM
Havoline Extended Life Dex Cool
mikes_box 03-10-2009 08:13 PM
i actually found the zerex g-05 at a local parts store after looking everywhere... did the flush because i had to replace the water pump... after getting the old coolant out i noticed it was the pink/orange color but the zerex is the green coolant... is that ok or should i drain it out and put the havoline dex cool in....
Blue-S 03-10-2009 10:23 PM
Zerex says that Dex-Cool is the appropriate coolant for late-model Porsches. Dex-Cool is orange, G-05 is yellow (except for factory-installed G-05 coolant in Chrysler/Dodge/Jeep, which is orange) and the traditional IAT coolant is green. Check these out:
http://www.valvoline.com/zerex/automaker.asp
http://www.valvoline.com/zerex/pdf/Zerex_CoolantChart.pdf?coaid=1B5D1AEA1AFC
Cloudsurfer 03-11-2009 06:08 AM
Supposedly the G-05 coolant is better, though that has yet be proven. Either way, Dex-Cool is the recommended coolant for these cars. I am probably going to run G-05 in my BMW when I swap that out in the near future, however.
