Old 03-09-2009, 06:24 PM   #1
Squish
We had two solid days of rain and when I looked in the car the area behind the drivers seat was wet. Is this a plugged drain? Also was some water under the fuse box in the left footwell.
Anybody have a good photo of the drains so I can go in a clean them.
urban_legend is offline   Reply With Quote
Old 03-10-2009, 02:43 AM   #2
http://mike.focke.googlepages.com/drainsdiagram
Step by Step instructions.... good luck.
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 03-10-2009, 04:03 AM   #3
UL, Have a friend spray the car with a hose while you sit inside and look for any water leaks, if the integrity of the top is compromised no amount of proper drainage will solve the issue.
eightsandaces is offline   Reply With Quote
Old 03-10-2009, 04:42 AM   #4
Yikes , might I suggest UL starts w/ a smaller amount of water... like a half filled 20oz water bottle pouring strategically in various places. Water leaks are very tough to chase down (if the drains are clear). While spraying a hose everywhere, you might not be able to correctly identify the area (especially since OP has standing water both in front off and behind drivers seat.
First thing first... make sure the it's dry around the black box underneath the drivers seat. If it gets wet all sorts of other bad thing$ occur. You should also protect this while doing any water leak testing just in case...
Anyhow, while clearing the drains (both in front trunk by battery and the rear), check the integrity of the foam liner which feed the rear drains. If it's pierced it won't much matter if the drains are clear. If there are tears/holes, I've heard others have used black silicone to seal them back up.
Good luck
Old 03-10-2009, 09:31 AM   #5
Where I live, that is a practical test of the real world, of course one should use prudence with hose angles and velocities, I guess I wasn't specific enough. If you have an absorber in your hand inside the car you should be just fine.
Old 03-10-2009, 03:46 PM   #6
black box
Some H20 did get arounfd the black box - I will dry asap. nice link to mike focke site - very helpful thanks!
Old 03-28-2009, 07:10 PM   #7
Good fortune!
Despite being soaked (2x) no problem.
Battery was also dead - maybe two wrongs made a right?
