Old 02-17-2009, 01:25 PM   #1
The truth about GT3 seats for tall drivers
I got my GT3 seat yesterday. I couldn't put it in until today. I took the stock seat out and set them on the ground side by side. The GT3 is as it came from Sunset Porsche with the rails and sliders. The stock seat is the same. I then took a box and set it on the floor in front of each seat. I placed one end of a level on the top of the box and held the other end above the seat (obviously level). I then measured from the bottom of the level to the center of the seating area (about 3" from the back of the seat). Your butt is exactly the same height off the floor in both seats.
So then I thought, "Well, the foam padding is definitely different. Maybe one is more compressible than the other. The GT3 seat certainly has less foam." So I decided to test it. I put the stock seat in as close to the same vertical position as the GT3 seat. To do this, I sat in the GT3 seat with my behind all the way back and my shoulders pressed firmly against the back of the seat. I had both legs stretched out straight in front of me. I then reached forward with my arms as much as possible while still keeping my shoulders pressed firmly against the seat. I marked on my knees where the tips of my fingers hit (actually, my wife did). I then sat in the stock seat in the same position and adjusted the seat until I was reaching the exact same spot. I then put each seat up against the wall. I sat as far back as possible (butt & shoulders) and sat up as tall as possible. I then had my wife set the level on my head and level it, then mark the bottom of the level where it hit the wall. Then I switched seats and did it again. The lines were identical.
So this tells me that if you are a tall guy looking to get more head room, the GT3 seat is not the answer by itself. You are going to have to spring for the BK tall man brackets and the floor mount adapter. If you want sliders, you are apparently screwed. As far as I can tell, if you removed the sliders from the GT3 seats, you would gain approximately 1" in headroom. Another option would be to remove the padding you sit on in the GT3 seat. This does lower you about an inch (I'm guessing). However, you are then sitting on the hard floor of the seat. That wouldn't be that bad, but there is an angle down right under the front part of your behind. I think that would get uncomfortable after sitting on it for about 10 minutes.
I am 6'4" with about a 35" inseam. I have been told by a few people that the only seats I could use would be the GT3 seat or the Recaro SPG XL. All other seats would have the harness holes too low, and I would be susceptible to spine compression in an accident. However, after sitting in the GT3 seat, I can see that the openings for the harness are just at the top of my shoulders. If you have a longer torso than I, the GT3 seat would be a problem in that regard also.
The upsides of the GT3 seats are that it is a racing seat; it will keep you from sliding around while you're driving hard, you can use it with a harness, and it is safe. Some people like the look of them; and for a racing seat, they don't make you look like a ricer. The downsides are: It won't give you any additional headroom without other mods, it's expensive, it's fairly narrow (I wear 36" waist pants and it's comfortable, but snug), you cannot adjust the seating angle, and some people don't care for the way it looks.
Now I just have to figure out if I should put the GT3 seat in, or sell it and put the stock seat back in.
Mike_Yi is offline   Reply With Quote
Old 02-17-2009, 01:42 PM   #2
ChrisZang's Avatar
very informative, Thanks
You saved me a lot of money as the main reason for me to get these seats would be to sit lower
The one thing I did not understand: did you get your seats from Sunset or from China (eBay)?
Old 02-17-2009, 01:43 PM   #3
Jaxonalden's Avatar
Mike,
How's the back angle? I'm 6' and I find that I'll sacrifice leg room and slide the seat forward and then lay the back down a little for a more comfortable ride. I'd hate to buy a set of seats and find I can't stand the fixed position. I'll stick with my stock seats, thanks for the heads-up.
Old 02-17-2009, 01:45 PM   #4
I got them from Sunset. Sunset had the best price on them that I could find. I guess Porsche just raised the price on them about two weeks ago. The leather are up around $1500-1700. Sunset is selling the cloth (which I prefer) for $1166.05. Shipping was about $140 for me. It may be more though depending on how Porsche ships the seat to Sunset. I think it could be as much as $30 more.
Old 02-17-2009, 01:58 PM   #5
That's a hard question to answer. I can't put a number on it because, like the stock seat, the GT3 seat back is not a straight line. I have always sat with my back at a pretty large angle too because it usually helps with the head room. However, I do find the GT3 seat to be very comfortable. It does feel very upright, but it's not so upright that it is uncomfortable.
To try to give you an idea of the seat back angle, I found a way to measure it. I set the stock seat as described above. I looked at the seat back for a flat surface, and the only part that was flat was the back side of the head support. I put a protractor on that part with the flat side against the seat. I then put a small level on the arm of the protractor. The angle it gave me was 96 degrees. If you imagine the protractor as a backward D, the arm of the protractor is pointing down at 6 degrees. That means that the top of the headrest is leaning slightly toward the front of the car. That seat position is, as far as I can tell, the same seat back position as the GT3 seat. They feel the same, or very close to it.
Old 02-17-2009, 02:12 PM   #6
FWIW, I VERY carfully test fit the seat in the car. I am so far from fitting in the car with that seat, it isn't funny. Because the seat back angle is so much more upright, I can't even sit with my head upright (it's tilted on an angle) because it pushes through the headliner on the hardtop and up into the roof. Even if I took the sliders out, I still wouldn't fit in the car with the GT3 seat.
I guess that makes my mind up. I will be putting the stock seat back in.
I contacted BK to ask if the Recaro SPF XL with their mounts, or the GT3 was lower. They gave me the measurement from the seat pan to the top of the seat, which is useless. I wrote them back asking about distance from the floor to the bottom of the seat. I never got a response. So now I have no way to figure out if the SPG XL would even work for me.
Old 02-17-2009, 06:20 PM   #7
Tall Guys in Boxsters
Hi, and thanks for the informative post. You are 6'4" with about a 35" inseam; I am 6'4" with a 34" inseam. I have only two problems. First, I have plenty of headroom but I worry about hitting my head on the roll bar if I get rear-ended (it would be a glancing blow but still . . .). Second, at times my leg will contact the cruise control stalk and my hands sometimes hit my knee when turning.
For the first problem, I am thinking of doing what Nurvus did in this post: http://www.renntech.org/forums/index.php?showtopic=11222&st=40&p=130404&#entry130404
and photos: http://s289.photobucket.com/albums/ll216/j...nt=rollbar1.jpg
By the way, I have checked the BK web site and I can't figure out what brackets would make the stock seat any lower. Suggestions? Worthwhile?
For the second problem, there isn't much I can do other than take out the console, which I don't want to do since it isn't that big an issue. However, I have wondered whether it would be possible to use a hair dryer to heat the cruise control stalk enough to soften it and move it upwards an inch or two? Has anyone tried this?
johnsimion is offline   Reply With Quote
Old 02-17-2009, 08:57 PM   #8
I forgot. I meant to post this additional information.....
I sat in the car with the seat out. In other words, I was sitting directly on the floor. He eyes were about at the top of the dash. I reached up to feel how much headroom I had, and the first thing I noticed was that my head would still hit the roll bar. Did you know that in the maintenance manual they describe the plastic part on the rollbar as "padding"? I imagine that it is some sort of energy absorbing material. Yeah, you'll have a headache, but you'll be alive.
Get the GT3 delete kit. It really helps. I was skeptical about it until I drove on the track. My right hand kept hitting my right knee while turning. I got the GT3 delete kit and my hand never hits my knee any more.
Old 02-18-2009, 03:37 AM   #9
edevlin's Avatar
When I got my GT3 seats with factory sliders I was also suprised at both the upright seating position and how high you were sitting. I got the BK brackets for factory GT3 seats that mount onto the sliding mechanism. Perfect, at least for me. They tilt the seat back more, which effectively gives you more headroom and lower the seating position about an inch as well. The BK brackets are not cheap, but made the seats work perfectly for me. Best of luck,
Ed
My Car Webpage
Old 02-18-2009, 07:54 AM   #10
Ed
That's great information. When I had the GT3 seats in I did not bolt them down. I tried tipping the seat rearward so the front bracket came up about an inch. Based on the pictures of the BK brackets, I figured that would be at least as far as those brackets tilt the seat. That didn't help much at all. It may have gotten me an extra 1/4" or so. Maybe.
I also tried sitting in the seat without the cushion in the car. I left the front cushion on. I could sit in the seat that way for quite a long time. Most of my weight seemed to be resting on the front cushion. At 220 lbs, removing that cushion gained me about 1/2" of headroom. I was still sitting higher than in the stock seat.
I suspect that part of the problem is that the headliner in the hardtop is lower than the convertible top. I'm going to heat up the garage today and find out just how much lower.
BTW, I didn't mention it in the original post, but my car is a '99 Boxster.
If I have to get the BK brackets, I will buy the Recaro SPG XL instead. When I priced out the two seats, the GT3 seats ended up being slightly cheaper. The Recaro seat is quite a bit cheaper, but by the time you end up buying all the BK hardware to mount it, it ends up being about $75 more. If I have to buy BK brackets anyway, the Recaro will then be the cheaper solution.
Old 02-18-2009, 09:28 AM   #11
Great Thread! Thanks for the detailed information.
I am (was) contemplating buying a 986, but at 6'3" with a 34" waist, the seat was going to be my first modification. Since my seat will need sliders, I think a 987 may be my only option (or a tall girlfriend).
Since Porsche designs the car, airbags, knee bolster, etc. for a wide range of body types, I think there is very little wiggle room in the driving postion.
Also, spinal compression due to improper belt height is a real issue. I had a T12 L1 burst fracture after a collision in a race due to an improper seat.
Thanks again for the great post!
teutonic986 is offline   Reply With Quote
Old 02-18-2009, 11:29 AM   #12
A 987 is going to be a high maintenance vehicle for sure, but nothing like the cost of keeping a tall girlfriend happy.
Get the 987. It may want more of your attention, but you'll never hear about it unless you have a loose belt, a worn pulley roller, or a wheel bearing that goes out on you.
Old 02-18-2009, 05:52 PM   #13
My solution
I am new here. Been lurking a while and decided I had something to offer.
I had the same issue in my 2002 S. I am 6'2" and 200lbs and always felt I sat to high in the car. 2 years ago I decided to solve it.
I bought 2 Recaro SPG's (non XL). They came with the stock Recaro sliders and adjustable side mounts. I then took the BK R-9040 Seat track adapter kit to mount the sliders to the floor and the mounts to the sliders. I mounted the seats as low in the brakets as they could go.
By doing this I gained around 3 inches of seat drop. Where I used to look through the top of the windshield, I now look through the middle to lower half of the windshield.
I am very satisfied with the change this made for me
mmuller is offline   Reply With Quote
Old 02-18-2009, 06:37 PM   #14
Stupid Question Dept.
Is the vertical adjustment of the stock seat limited by the electronic whatzit that's under the driver's seat? If so, can the whatzit be relocated to under the passenger's seat? I am just looking for an inch or two additional clearance from the rollbar on the driver's side (my passenger is 5' tall and height isn't an issue). I can't see investing $1500 to $2000 for a couple of seats for a 10 year old car.
Old 02-18-2009, 10:13 PM   #15
That's pretty much what I've decided to go with Mmuller. I sat in a Boxster with Pole Position seats + sliders and had much more headroom. If you look at the BK brackets, they have more adjustment holes for reclining more too. I've been told that the BK brackets will let you lower the seat even further, though I have come to trust those people less now. I've also read (in only 1 place) that the Sparco slider is actually lower than the Recaro slider. BK's brackets work with the Sparco slider. I have to call BK tomorrow to ask them about that. I'll let you know what I find out.
By any chance do you still have the stock seat around? If so, could you do what I did (first measurement I described) to measure to see just how many inches lower the SPG is from the stock seat? It would require you to pull the Recaro seat to get a really accurate measure, but it would be great info for people like us.
Not that I can tell John. I looked at the stock seat pretty carefully. I was trying to figure out if there is a way I could modify it to lower it. It could be done. There is a piece of metal between the seat frame and the sliders. In the front it could save you about 3/4" to an inch. The problem is that in the back it would only save about 1/4" unless you actually modified the seat frame. Most of the space up front, I think, is for the shock that pushes the seat up when you are raising the seat. Us tall people don't care about that, so that could come out. It wouldn't help in the back though.
Old 02-19-2009, 04:39 AM   #16
Sorry
Sorry, I no longer have the standard seats. I was so happy to get the seating position finally right that I was happy to let go of them.
If you want to retain the standard seat belt and buckle, you will also need to use the BK-9005 Tunnel side seat belt anchor. This gave me a mounting point at the tunnel for the buckle and allowed me to retain the use of the standard seat belt. The car has been through 2 state inspections and they always comment on the nice integration of how it looks.
I can tell you that there is no more than a quarter inch between the bottom of the seat shell and the floor of the cabin. I could go one notch lower, but I would have to machine the side brackets somewhat as the side hole for the harness would foul with the bracket.
Old 02-19-2009, 09:04 AM   #17
Do you use a harness at all? BK tells me that if I go with that solution I cannot use the anti-sub strap mount bar. That kinda defeats the purpose of the race seat (other than for getting more headroom).
They tell me if I want to use an anti-sub strap mount bar, I have to go with the R-9075 side mounts with the stock sliders. That will cost me 5/8"-3/4" of headroom. I want to put in a 6-point harness for DE, but I need all the headroom I can get.
What to do? What to do?
Old 02-19-2009, 11:24 AM   #18
I don't use a harness (not yet anyway) as my goal was to get comfort and safety first and then worry about track days, which is still on my to do list.
I looked at the anti sub brace just now. At least in my install, I dont see why it would not work. I dont have the BK side brackets however. Mine came with the seat and were supplied by the company I bought them from, but I can't recall who that was as it was over 3 years ago. I think it was Speedware Motorsports. I still dont see why they wouldnt work with the BK solution however
Old 02-19-2009, 12:20 PM   #19
I talked to BK again. I was wondering if their R-9773 brackets would mount the Recaro seat directly to the floor. It won't. They don't have a solution to mount it without sliders (which seems odd to me). If I have to, I'll fabricate an adapter myself for track days to get that extra inch of clearance.
Anyway, while talking to them again, I found out that the R-9062 (which is for use with the Sparco or Recaro sliders) WILL work with the anti-sub bar. It's just the R-9062s and the sliders aren't drilled out for it. The guy I talked to was one of the engineers at BK and he told me that lots of people do it and it works well. So it's not a clearance issue, it's just that the parts need to be drilled. BTW, the BK guy was VERY helpful.
So what he said to do is put all of the hardware together with the seat out of the car. Determine where the sub mount bar should be located. Mark the holes. Take it all apart and drill the holes with a cobalt bit. Since the BK parts are made of stainless steel, you have to use a cobalt bit or you will go through a ton of bits trying to drill it out. Finally, put it all back together. The holes need to be drilled in the bottom of the seat side brackets, and in the top piece of the slider.
I ordered all of the stuff I'm going to need from Stable Energies. The guy I talked to there was also SUPER helpful. After I gave him the list of everything I was ordering, he offered to have one of his installers double-check to make sure that should all work. Of course I took him up on it. I should have all of it on Tuesday, so I'll update the thread with the comparison between the seats then.
Old 02-19-2009, 02:57 PM   #20
My carbon fiber seats are lower than the stock seats. They are GT3 design but smaller I guess. When I first installed them I had to re-adjust my rear view mirror due to the height difference. They are for sale, check the classifieds if your interested.
SilentThunder is offline   Reply With Quote
