radio problem
I have a becker cdr -220 in my 2000 boxster I got a ipod connector for it i folloed the great instructions. I had to press in the TP button util becker 1 shoed up turned knob to AUX which was off. I turned it on .Turned off radio and plagged in ipod into connector. I was then instruced to press and hold "S" button on radio until AUX showed up again IT did not . All is hows is NO CD and does not show AUX . any ideas what is wrong? Its seams that everthing is working ok This is my 2nd cable The person took it out of his '99 boxster and sent it to me. It is just not recoginising it
I would appreciate any advice thanks Ncox615 |
Pull your faceplate and clean the contacts on the FP and HU, then carefully realign and replace. That should take care of it.
Hopefully LB's advice worked for you. Welcome to the forum. |
Ncox615 got his stereo to recognize the AUX port and the cable connected to it. Cleaning the contacts did the trick. I know this because I was the one providing the cable. We're both quite happy to have things working now.
If any of you folks are looking for a way to connect your iPods with your CR/CDR-220 head untis, let me know. Cheers, -Jeremy |
CDR 220 Aux (ipod recognition)
Hey there! My first response of any kind, hope it helps someone. The Ipod cable I ordered from Blaupunkt had a blue plug for the C3 location @ rear of unit, a fused red wire for Lighter or whatever +12 source you chose, & a black ground wire. Simple. As usual, I got what I needed from a 986Forum dude. I held in the 'TP' button to get to the menu & scrolled to the 'aux on/off', but it would not switch. Another user said to clean the contacts on the back of the faceplate & unit. So I started over again, this time with the Ipod blasting a signal which was quickly recognized & I got it switched to 'on' & with the 's' button my toxic tunes abruptly blasted a smile on my face! Call anytime, Martin 253-514-9002
| All times are GMT -8. The time now is 12:11 AM. |
