Old 02-01-2009, 02:46 PM   #1
Bobiam's Avatar
Recommended spark plugs for my '01 Boxster
My Box is an '01 with 35,000 miles. Still has origingal plugs and runs fine, but per manual should have had plugs changed 2-4 yrs ago (depending on what manual or guide you happen to have).
What plugs are recommended by you guys????????
Bob
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
Old 02-01-2009, 03:15 PM   #2
07 Carrera S Cab
Boxtaboy's Avatar
Bob
I use the OEM recommended plugs which are made by Beru. They cost a little more than some others, but I think they're worth it.
http://e-partssales.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=986plu&Category_Code=986engele
Old 02-01-2009, 04:59 PM   #3
Jaxonalden's Avatar
I replaced mine with OEM Beru's, $13 a piece. Bosch also has a multi ground electrode plug in heat range 6, P/N FGR6KQE, they're about $8 a piece.
http://www.partsgeek.com/ntparts/2000/porsche/boxster/spark_plug.html?utm_source=yahoo+shopping&utm_medium=pf&utm_term=Porsche+Boxster+Spark+Plug+-+Beru&utm_content=mmbpp_limited&utm_campaign=PartsGeek+Yahoo+Shopping
Old 02-01-2009, 08:43 PM   #4
Lil bastard's Avatar
Stick w/ oem.
Exotic metal plugs are mostly marketing hype and the only real supposed benefit is longevity. Longevity isn't really a plus on a car that's driven for performance or where the plugs are so easily changed, especially on a car where the mileage spec is already 60k mi. to begin with.
Aftermarket plugs may not be indexed properly and there is no universal standard on heat range. One Mfgr.'s #6 does not necessarily equal another's #6.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 02-02-2009, 04:00 AM   #5
Jaxonalden's Avatar
Originally Posted by Lil bastard
Stick w/ oem.
Bosch, aftermarket? Beru isn't made by Porsche so that would make them aftermarket also. The Bosch plugs suggested aren't Platinum or Iridium, like that would even matter. You won't go wrong Bosch (~$50) or Beru (~$90)...just about a $40 difference in price for six spark plugs.
Old 02-02-2009, 07:18 AM   #6
I guess I'm a little confused Jax. You recommend and defend Bosch, but you replaced with the OEM Beru plugs??? Pick one....
fastorange is offline   Reply With Quote
Old 02-02-2009, 08:20 AM   #7
I don't think you totally understood my reply.
The Plugs Bosch #FR7LDC4, FG6LDC, and Beru 14FR6LDU, 14FR7KQU are all OEM plugs used by Porsche interchangeably (depending on your engine displacement).
These plugs were selected and then the heads tapped so that when properly torqued (22Ft.Lbs. new, 18.5 Ft. Lbs. used), they are inset optimally in the heads(depth) and their spark is properly aligned with the desired flamefront travel. Also, their respective heat ranges are close or matched too.
I suspect that none of these are better than any of the others spec'd, so if you can save on one over the other, so much the better.
But, there have been reported issues when using other plugs than these spec'd. Specifically, some of the other Bosche Platinums have been reported to have broken electrodes inside the motor which have caused some cylinder/piston scarring.
1976 BMW 2002
1990 BMW 325is
Old 02-02-2009, 08:35 AM   #8
07 Carrera S Cab
Boxtaboy's Avatar
The Beru's are $68 bucks from the Suncoast Porsche Dealer link I posted above, so it's not that much of a difference in price.
