Old 01-20-2009, 12:17 PM   #1
Alarm goes off for no reason
I have a 2001 Boxster and the alarm will go off for no reason. After the alarm is set and the car has set for 3 or more hours and then alarm goes off. I do not know what could be causing the problem....Any suggestions.
Thanks,
Dennis
lemieud is offline   Reply With Quote
Old 01-20-2009, 07:37 PM   #2
I had the same problem The culprit was a loose connector according to my tech. fixed it in 5 minutes.
Michael
http://imgur.com/aiZcIk8
986FortyEight is offline   Reply With Quote
Old 01-21-2009, 05:55 AM   #3
ppbon's Avatar
If you have any other electrical gremlins it could be the ignition switch.
I've seen this a few times. Everything electrical goes through the switch which is spring loaded and in a switch that's started to crack it can "jump" by itself sometime after the key is removed.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
