Old 12-15-2008, 03:36 PM   #1
Another electrical system question
This is an offshoot from my “Battery choice” thread.
Having been pretty convinced my battery was dead or dying, I had disconnected it from the cables in the car. (I was curious what it weighed.) I decided to charge it on a trickle charger for a few hours. A few hours after finishing that, it dawned on me that I had this analog multimeter, so I dug it out and checked the battery. It read better than 12V. Decided to put it back into the car, which started up nicely afterwards. (A couple days ago, I was left stranded away from home when the engine---having started an hour earlier---wouldn’t crank.) Went for a drive, pretty much everything was fine. Got back, shut her down, checked the voltage again. Again, it was over 12V. The question: the part that was not “fine” on my drive was the fact that the battery light came on (and stayed on).
Suggestions as to why? Is it probably just due to a bad battery, or do I likely have something more serious, like an alternator problem? Or is it impossible to speculate intelligently without additional diagnostics?
Thanks for any ideas.
Old 12-15-2008, 05:04 PM   #2
Porscheectomy
If you take it to an auto parts store, they can test the health of the charging system (alternator) and the battery's ability to hold a charge.
Old 12-15-2008, 05:26 PM   #3
Shazam! Why didn't I think of that?!
Thanks.
Old 12-15-2008, 05:51 PM   #4
Jaxonalden's Avatar
Nice thing about a load bank from an auto parts (AutoZone) store is it's free!! And they'll tell you what part is bad.
Old 12-15-2008, 06:38 PM   #5
Lil bastard's Avatar
You really s/b seeing 13+ volts if the battery is healthy. 6 wet cells, each producing about 2.2 volts wired in series.
If the battery is hooked up and the car running, you s/b seeing 13.5-14.5 volts for the oem bosche alternator.
If not, check cables for resistance and load test the alternator and battery. As mentioned, several parts stores will do this for free.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
