Old 11-02-2008, 01:44 PM   #1
Send a message via Yahoo to TimAustinW
To replace exhaust is it safe to only use 2 jack stands?
I've never put my Boxster on jack stands. I recently acquired some Maxspeed Headerss with Cats and secondary bypass pipes. It seems like a pretty simple straight forward installation. I've read through all the posts on jacking and I couldn't find any answers concerning using only 2 jack stands. I have a hydrolic floor jack and two jack stands capable of supporting 3 tons each. Is it safe enough to only jack up the rear of the car or am I asking for trouble? The idea of being under 3000lbs scares the crap out of me.
Thanks, :dance:
Tim
TimAustinW
http://i226.photobucket.com/albums/d...ignature-1.jpg
02 Seal Grey, NHP Headers w/ Highflow Cats/2ndary Bypass Pipes, smoked side markers/3rd brake light, exterior match interior trim, 986 Lloyds Mats, 986 deck lid emblem, arctic silver intake grills, ipod link, painted calipers, Glass Window Robbins Top with defroster kit, Bose Sound System, Leather lower door panels, Console Lid w embroidered crest; Stainless door sills; Painted Bumperettes; Custom Hood Crest
TimAustinW is offline   Reply With Quote
Old 11-02-2008, 02:35 PM   #2
Yups, two stands in the rear is fine... no need to jack up the front...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 11-02-2008, 02:40 PM   #3
You can also use the center rear jacking point. Place the jack here...
http://986forum.com/forums/attachment.php?attachmentid=4420&stc=1
with a piece of wood to distribute the load and then place the jack stands at the 2 rear lift points. My floor jack is not low profile so I back the car onto 2 pieces of 2x8 wood to raise it up a little bit so I can move the jack handle enough.
derb is offline   Reply With Quote
Old 11-02-2008, 02:55 PM   #4
Lil bastard's Avatar
Just be sure to chock the front wheels for safety's sake.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 11-03-2008, 09:41 AM   #5
pk2
Leave the floor jack in place with some tension on it. Chock are good. If I have to take my floor-jack out for access, I usually add 1 or 2 cheapo jack stands (from a box store) and wedge somewhere out of the way.
(Click on signature pic)
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
Old 11-03-2008, 11:07 AM   #6
There Is No Substitute.
rick3000's Avatar
You might consider using ramps if you're only doing the exhaust. Thet tend to be sturdier than jack stands and are easier to use. Plus, I share your fear of being under a 3000 lb. car, and ramps frighten me less than jack stands.
