Old 10-30-2008, 11:49 AM   #1
Loosing my mind please help
I brought my boxster in to get my water pump fixed. With the replacement and belt and a broken oil line it cost me $1600. Then a month later the coolant started spraying on the roof of the trunk and check engine light came on. It is also having trouble starting after I have been driving it for a little while. It starts up fine when it is cold.
Now I brought it to a Porsche dealer instead of mechanic to make sure they would fix it. I just spent another $800 and they said some oil line was bend and the coolant camp was stripped so they put a new one in. I just got home and the check engine light came on. It stalled going in reverse. It took 20 seconds for the car to turn over and there is coolant and steam coming out of the coolant cap again. Same problem from both places.
I am about to loose my mind. Does anyone have any clue what is going on. Someone who is not a mechanic said that they think the head gasket has a crack and forcing the coolant back into the system or something like that.
Anyone experience this
thanks
Joji is offline   Reply With Quote
Old 10-30-2008, 01:50 PM   #2
Sorry about your troubles. I can't help you out, but I see you are from Orlando. There is a very good porsche mechanic in Orlando called Red Bone. I had a 928 in the past and they were excellent with reasonable prices. You may want to check them out.
Good luck.
Eric
E Kaplan is offline   Reply With Quote
Old 10-30-2008, 02:12 PM   #3
I'm curious as to what failure mode of the water pump caused an oil line to be damaged. My water pump failed on me a couple months ago in the usual manner - the bearings failed and the impeller disintegrated. Replacing it (and the belt and changing the oil and filter) only cost me about $200 to do myself. It's stupid easy, if you're somewhat mechanically inclined.
I would REALLY doubt a water pump failure would have caused any damage to any lines.
Secondly, I am getting the impression that your dealer is, well, incompetent. You should not have similar issues after they've already replaced all those parts. I'd have someone else check it out.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
Old 10-30-2008, 02:27 PM   #4
Hmm, I'm no expert, but it sounds like it could be two separate issues. I seem to recall there being an issue with faulty coolant tank caps, that could be causing that leak.
Now this is a wild speculation on my part... the only possibility I can conceive of regarding the oil line damage as a result of the water pump failing is if the water pump seized and subsequently broke the belt which they may have hit the oil line.
In addition to Redbone, there is an independent garage I use named Zotz over here in Winter Park (Near 436 and Howelbranch), the garage is literally behind the Original mattress factory on 436. There is also Troysport off SilverStar west of OBT.
kabel
kabel is offline   Reply With Quote
Old 10-30-2008, 03:27 PM   #5
Thanks for the tips. I just brought it back to the porsche dealer. I actually moved to CA. I live in Valencia outside of Hollywood.
The main mechanic came out who fixed it. He was very nice. He was dumb founded. They are looking at it again for no additional cost of coarse and a nice rental at least. But I rather have the problem solved then deal with the headaches.
He is not sure what it is. The parts he fixed is what the computer told him. I asked him about the head gasket. He did not think that is what it was and not the starter problem. He said it is probably related to the oil line which also makes the car have trouble starting
Old 10-30-2008, 03:40 PM   #6
There Is No Substitute.
rick3000's Avatar
The coolant tank going is common, and water pumps go on all cars after a while. It sounds like you where just unlucky and had them both happen fairly close together. I don't think that these two things are related. I'm curious how many miles are on the car?
