10-23-2008, 01:56 PM
Oil change - O ring replacement
Had an oil change question. I've got the filter off and am replacing the O-ring on the housing. My question is where exactly it goes.
Does it go into the channel right next to the threads, like this:
Or, does it go right up against the flange, ie a little further from the threads (though in this pic part of it is not quite totally up against the flange), like this:
I'm thinking the first choice is right, but I wanted a second opinion.
Thanks in advance.
10-23-2008, 03:33 PM
First, your camera should have a 'macro' function. That allows it to focus on things REALLY close. The symbol on the corresponding button looks like a flower. (just trying to help)
Second... I THINK it goes in the channel. I changed my oil a couple weeks ago... and the o-ring.. but darn if I can't remember 100%
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
10-23-2008, 03:44 PM
Porscheectomy
It goes in the groove next to the flange. If I squint, it looks like your second picture. If you don't get it in the right place, the car will tell you very quickly by pouring oil all over the ground.
10-23-2008, 04:12 PM
OK, anyone want to chime in as a tie breaker?
Actually, I have changed the oil in the Box once before and I'm pretty sure I put it in the channel (Photo 1), and it didn't leak. The last time it was changed, I had Porsche do it in conjunction with the 30K maintenance (for warranty purposes, I wanted to have them do that one). When I removed the filter housing today, that is where I found the O-ring (ie, in the channel). And I've never had problems with oil loss.
But I got to thinking about it, and it just seemed to make sense that one would put the ring right up against the flange (Photo 2). However, when I'd put it there, it had a tendency to want to roll off back into the channel (as in Photo 1).
So I'm sittin' here with an oil-less vehicle that I'm hoping to take to work tomorrow. I have replaced the drain plug, and the filter, with the O-ring as in Photo 1. And I'm just itchin' to pour fresh oil back in so she's drivable. And Game 2 of the Series is about to start. And I've had no dinner. And I need to go pick up my son from a friend's house. HELP!
10-23-2008, 07:16 PM
Porscheectomy
It should be the deeper groove. It's really hard to tell in the pictures but if that's a bit down from the flange, then that's it.
If you've got it on and it's not pouring oil everywhere, you've done it right.
10-24-2008, 05:18 AM
I put it in the channel, as in Photo 1 (ie not directly against the flange). It just seemed to me that an O-ring (that, if cut, would be circular on cross section) should fit into a channel and not up against a flange. (It's not a flat gasket after all.)
Anyway, fired it up and no leaks seen so far.
On a related matter: How many people actually use a torque wrench to achieve "25 Nm/19 ft-lbs" on the filter housing? As long as you don't strip threads, is it possible to over tighten it??
BTW, Fray, you're right: lousy pics. (Had I been running around with my camera specifically seeking out stuff to shoot, I'da thought of hittin' the Macro. For some reason yesterday I didn't.)
10-24-2008, 06:42 AM
Originally Posted by Frodo
...On a related matter: How many people actually use a torque wrench to achieve "25 Nm/19 ft-lbs" on the filter housing? As long as you don't strip threads, is it possible to over tighten it??...
Yes it's possible to over-tighten it, though not likely if hand turning it! Being plastic, it can warp and come away from the mating surface in spots, or the 'o' ring can get crushed, both allowing leaks. Also, you could easily strip the threads in the housing again because they're plastic.
But, just as w/ a spin-on oil filter, you should 'lube' the 'o' ring and then hand-tighten it, this is the best - not going to get near 19 lb.ft. with just your hand.
