Old 10-18-2008, 09:21 AM   #1
Convertible Top Question
I have a 2003 Boxter S. The convertible top seems to be working just fine. However, there is a warning on the msg. center which reads "top not in limit position." The indicator light for the top is also on. The top opens and closes normaly and seems to be closing completely. Could this be a microswitch problem? any ideas?
futureman is offline   Reply With Quote
Old 10-18-2008, 10:00 AM   #2
First off - welcome to the forum!
When you open and close the top, you need to hold the switch down until the light shuts off - not just to the point where you think it's opened/closed. Are you doing that? If not, cycle it thru until the light shuts of and all will be good again!
