Old 10-15-2008, 12:16 PM   #1
How do I top-off or change the Manual Trans. Oil?
Looked inside the owners manual and it just says take it to an authorized dealship. Is it located in the service mode/engine area? I only saw the power steering fluid resiviour. Isn't there a way to check the manual trans. fuild level?
porsche986spyder is offline   Reply With Quote
Old 10-15-2008, 01:45 PM   #2
Porscheectomy
http://www.renntech.org/forums/index.php?showtopic=7060
The difference is that you're not supposed to fill up to the fill hole in the boxster. It's supposed to be something like 11mm under the hole level. I don't have the Bentley manual handy right now but I think it's shown there.
Old 10-15-2008, 02:39 PM   #3
Okay, but is there a dip stick like there is for the regular oil checking? Or is it just a visual container like the brake fruid area has that you can see clearly where to stop because the container is clear plastic and has markings? Is it at least reachable in the service mode? I have the Bently manual at home. Guess I will look it up when I get home.
Old 10-15-2008, 03:25 PM   #4
Porscheectomy
No to all of those questions. You have to make your own dip stick with a hanger or something to reach into the hole to see what the fill level is. And it's all done from under the car, you can't change the transmission fluid from above. Although you could fill it by adding oil through a hose, I suppose. I just use a hand pump with a 1 quart capacity.
