Old 10-11-2008, 10:09 AM   #21
There Is No Substitute.
rick3000's Avatar
Some Boxster's have problems with the fuel gauge sticking. So when you fill up the tank is full, but the gauge gets stuck at 3/4 full. And the same thing can happen for low fuel. The gauge gets stuck at 1/4 tank, but their is less gas than that.
I have noticed that the OBC fuel gauge is based on your OBC average mileage. So if your OBC average mileage is very high (say from a lot of freeway driving), and then you go driving around town, the OBC may be giving you an estimated range based off your average MPG but not your actual MPG.
I'm glad you got it fixed and wasn't anything serious! My dad used to run out of gas all the time doing, "aerodynamic testing," in his 944.
Old 10-11-2008, 10:45 AM   #22
Smile
Thanks Rick...I guess I'm still in shock that it's running...I must admit I'm a little paranoid about driving it right now but that will pass...again, thanks for taking the time to help me!!
cjweiss is offline   Reply With Quote
Old 10-12-2008, 06:02 AM   #23
if you have a sticky fuel sensor what is involved in getting it fixed, (expense wise)? I have been having an issue with not being able to fill the tank with fuel because of what I thought was an air lock issue. sometimes at 1/4 tank I can only get half of what I think should go in and then the guage reads only 3/4 full. However after reading this maybe my guage sensor is totally wrong. I think the problem really is more of an air lock issue with mine as I can drive a little and then get more fuel in. To fill it up. Possibility is both problems are in play here.
Ken
SoCalKen is offline   Reply With Quote
Old 10-12-2008, 11:54 AM   #24
Topless's Avatar
That was easy!
The fuel gauge on these cars is somewhat unreliable . A little German quirk. Sometimes it sticks at full, sometimes the float gets soggy and never really reads full (mine). You can change it out but the word on the street is that the new ones aren't much better. To overcome this I just reset my trip log at every fill up. Once I log about 250 miles I know the gas gauge means business. Time for gas.
You would think they could figure out how to solve this simple problem.
