Boxster General Discussions
Loose door sill
08-21-2008, 10:41 AM
Lordblood
Loose door sill
I have found that the metal door sill on the drivers side has come loose, almost to the point where they will come off completely. Should I just use krazy glue to put it back in place? Or is there a different approach to this?
http://i56.tinypic.com/5eyeme.jpg
08-21-2008, 11:12 AM
2
Burg Boxster
use 3M trim adhesive - either the goop kind of the double-sided foam tape (easier to work with). Can be found at most auto supply stores.
08-21-2008, 04:00 PM
3
Lordblood
Originally Posted by
Burg Boxster
Alright thanks
08-22-2008, 09:35 AM
4
Mike_Yi
I've got the same problem. Thanks for asking. Now I don't have to.
Linear Mode
Switch to Threaded Mode
06:16 PM
