-   -   Hit Bump, power windows go down (http://986forum.com/forums/boxster-general-discussions/17735-hit-bump-power-windows-go-down.html)
Nick 986 07-30-2008 04:51 PM
Had a weird one happen today. As I was driving out to the beach, I drove over a small bump across the highway. It was an area that had some patchwork paving done at some point. It was a small bump nonetheless but whan I drove over it I heard a click and my windows went down the same distance as if I was putting the convertible top up or down. I tried to put the windows back up and they would not move. I could put them down but they would only go back up to that point and no further. I opened the handle on the convertible top and closed it back up and the windows worked fine. This happened to me once before about three years ago and today was only the second time it happened. Obviously it is extremely intermittent but I am just curious as to what would cause this to happen. Thanks again in advance for your replies.
derb 07-30-2008 06:04 PM
Nick,
Very common problem. I have a piece of duct tape on the micro-switch to keep that from happening. If that works loose I pull the latch down and push the switch with my finger.
The micro switch part number for up to a '99 is 986.613.795.02. Model '00 up is 986.613.799.00. Pretty easy to replace. 987 part number could be different.
Regards,
mike
Nick 986 07-31-2008 05:31 AM
Derb,
Thank You for the advice. If it happens again soon I will try the duct tape. I am heading to Halifax (approximately 2 hours from here) to see Elton John in a few weeks so I will stop by the Porsche dealer to get the part. Thanks Again!
