Old 07-30-2008, 04:25 AM   #1
2004 Boxster oil drip
Hello All:
I have noticed a small, occasional oil drip from beneath my 04 Boxster. It is towards the front of the engine and just sort of hangs there for extended periods of time on the lowest point before dropping. It is due for its first oil change now at 24000 kms.
Any comments would be appreciated as to whether I should start investigating further.
Thanks,
Grant
Boxster PEI is offline   Reply With Quote
Old 07-30-2008, 06:08 AM   #2
With an '04 and only 24K kms, you are probably near the end of your warranty. As such, I'd have the dealer take a look at it ASAP. It could be as simple as a loose drain plug or...... it could be something not so simple . Definitely if you're still in warranty, have them check it out ASAP.
Good luck
