Old 07-26-2008, 06:27 PM   #1
sewage like smell in car when driving any idea?
I sometimes get a faint sewage like smell in the car. sometimes I think its coming from the outside environment but Im starting to think maybe its from the car. My car is not driven often could this be behind the reason or would it be some sort of leak? its not too bad and goes away after a while but just curious if anyone has had this and knows what it could be?
2001 Boxster S
Gemballa front bumper/Aerokit I Sideskirts/H&R suspension/997 short shift/Schnell front&rear strut brace/Aluminum pedals and floor board//Traffic pro/Console Delete//LED exterior lighting//Exclusive Options Full Leather/19inch Ruf Wheels/European rear bumper with 550 mesh/Zientec spoiler/IPD Plenum//Cold Air Intake/Hardtop/Speedster Humps
Stunin_Stud is offline   Reply With Quote
Old 07-26-2008, 07:20 PM   #2
bmussatti
Posts: n/a
Is your AC working properly? Does the condesation from the AC properly drain to the outside of the car?
Are you missing a lunch bag? Dead mouse?
Old 07-26-2008, 07:39 PM   #3
I rarely use my AC but I see what you mean cuz this smell would be associated with it. how would I check the drainage?
I hope its not a mouse, cuz not only would it be a ******************** to find I would hate it if it chewed any wires.
thanx
2001 Boxster S
Old 07-26-2008, 08:28 PM   #4
Dude check for mold from clogged drains.
Take the front/side battery cover off and inspect the entire area for a rodent.
Take the cabin filter out and smell it.
Old 07-26-2008, 08:55 PM   #5
Porscheectomy
Try driving the car around without the ac on. See if you have the smell. If not, then turn the ac on and then check for the smell. If it only smells when you first turn on the ac, you have mold build up in the condenser or ducting. If this is the case, it's most likely not a drainage problem, moisture in the condenser can't be avoided. There are some products you can buy to spray into the vents, these might work, otherwise, you're looking at a disassembly and cleaning of the condenser and maybe some of teh ducting..
You can avoid this in the future by turning off the ac but leaving the fan on a couple of minutes before you turn off the car. This dries out the condenser to keep mold from growing.
Old 07-26-2008, 11:05 PM   #6
If its a sulfur like smell or rotten eggs smell it may be your catalytic converter. Common symptom have it checked.
2000 986s
http://i25.tinypic.com/2a4v7yr.jpg
boxs2000 is offline   Reply With Quote
