-   -   Precotion before Welding on a Boxster (http://986forum.com/forums/boxster-general-discussions/17541-precotion-before-welding-boxster.html)
vipola 07-14-2008 04:03 PM
Do I need to do other precotion than unpluging the battery?
I blown up a part of the electric system on my Kawasaki Ninja many years ago because i din't unplug the battery before weldering, is there other precotion to have on a porsche? thanks :)
wvicary 07-14-2008 05:01 PM
I've heard you should disconnect the ECU but I never have but I do use a surge protector that clamps onto the battery. I purchased it from Mac Tools and it's designed to protect the electronics from arc/wire feed welders.
Lil bastard 07-14-2008 08:16 PM
From the 986 Factory Manual:
Electronic control modules
Note!
Protection against overvoltage
To protect electronic control units from overvoltage during electric
arc welding, the following work regulations must be observed:
•When welding work is extensive, the electronic control units
must be removed. Ensure that there are no electrically insulated
parts between the earth connection and the welding point.
•Remove clamp from negative terminal of battery and cover negative
terminal of battery.
•Connect the earth connection of the electric arc welding equipment
as near as possible to the welding point on the part to be
welded.
•Do not touch electronic control units or electric cables with the
earth connection or the welding electrode
