Old 06-30-2008, 01:17 PM   #1
Tougher than normal Steering, low fluid?
I havent check the power steering fluid since i bought it 2 months ago but I've been readin I should have. The steering feels tougher than normal but still feels like im getting some assist. Could the slight toughness come from a low fluid? If it is im doing it right after work :dance:
BoxsterLewis is offline   Reply With Quote
Old 06-30-2008, 02:05 PM   #2
Send a message via MSN to CJ_Boxster
Could be that its low enough to where it is pulling in air into the pressure line which will cause toughness and premature wear on your power steering pump... check the level quickly and also check your tire pressures.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
