Old 06-06-2008, 05:10 PM   #1
Question How to have Pedro Sports Exhaust installed?
I want the Pedro style sports exhaust modification done on my car as soon as possible.
Is there a link somewhere that explains in detail how to do this mod so I can tell a muffler or performance shop what I want done on my exhaust?
Jacques79 is offline   Reply With Quote
Old 06-06-2008, 05:32 PM   #2
Its basically welding a one inch pipe from your mufflers inlet to your mufflers exhaust tip.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 06-06-2008, 06:43 PM   #3
So I just tell the mechanic I want to weld a one inch pipe from my mufflers inlet to my mufflers exhaust tip and he will understand everything?
Is it the same with the Boxster S than the standard Boxster since the mufflers are different?
Old 06-06-2008, 08:27 PM   #4
There Is No Substitute.
rick3000's Avatar
Can you do this to a base Boxster?
Also, could someone list the pro's and con's. Wouldn't you get more resonance?
Old 06-07-2008, 06:54 AM   #5
Finding a shop that will weld stainless steel properly ain't easy here in Houston.
Old 06-07-2008, 08:50 AM   #6
I did this
I had an S muffler modded this way. Living in a small city in Louisiana, none of the welding shops had the stainless steel tubing, so I did an internet search and bought the tubing and pre-bent angles (stainlees steel requires mandrel bending, which your shop may not be prepared to do) and then had a local shop do the welding and install. If I had to do it again, I would go with a larger diameter pipe - the 1" really is not loud at all. And no resonance. Do some searches on the various Boxster forums and you will find plenty of info and pictures.
musicboy is offline   Reply With Quote
