Old 05-24-2008, 02:47 AM   #1
Purpose of Wheel Spacers?
What is the purpose the wheel spacers people are putting on. It's an added tequipment. I mean it adds 5mm on each side to a total of 1 cm combined, I can hardly see how that affects performance. Is this just a looks thing?
hqduong is offline   Reply With Quote
Old 05-24-2008, 10:07 AM   #2
a bit of each
I would venture to say that it is mostly a looks thing, however, as you observed, the overall track is a bit wider with the spacers. Some might argue that the slight change in suspension geometry is not as much of a 'negative' as the addeded track width is a 'positive'.
As for your recitation about the spacers being 5mm - while those are likely the most popular, and the least likely to cause any adverse effects, significantly larger spacers are available.
2003 Boxster S - Speed Yellow
Sloan is offline   Reply With Quote
Old 05-27-2008, 02:06 AM   #3
search the forum, and read some more...
in a nutshell, looks, and handling. and to fit wheels that otherwise wouldn't clear your shocks/brakes.
http://b-ng.com/audi/images/avatar.jpg
Benny
lubrify.com
Benny986 is offline   Reply With Quote
