Old 05-21-2008, 10:58 AM   #1
Humming sound when clutch pedal is engaged?
This happen to anyone and is it a sign on anything? Seem to only hear it at idle when i engage the clutch and feels a little different when letting go now?
BoxsterLewis is offline   Reply With Quote
Old 05-21-2008, 12:03 PM   #2
Send a message via MSN to CJ_Boxster
could be the throw-out bearing is making the noise. Usually thats the cause of noise.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 05-21-2008, 12:12 PM   #3
That sounds right, that mean its going bad? I havent abused the clutch at all.
Old 05-21-2008, 12:16 PM   #4
Well technically Yes, the only way to cure that is to apply the small amount of grease that has worn off/disapated, But you might as well install a new one, It happens from time to time on manual transmissions and some end up never having noise from it... luck of the draw i guess.
Carlos J Cazares
