Old 05-17-2008, 01:44 PM   #1
Track rat
Topless's Avatar
New Understeer Problem
A little background first:
98 Box 2.5L, 75k miles, tires PS2's 225/45/17Front, 255/40/17 rear, performance alignment Camber -.7 deg. Front, - 1.4 deg. rear, zero toe front and rear. Two years Auto-X / track experience.
Last year in Oct. my rear tires were down to the wear bars, lap times were suffering a bit and I had a few spins on corner exit with snap oversteer on rough surfaces. The tires were actually 4 years old and I figured the rears were toast. Front tires were only 1/2 gone and still felt ok. I put new PS2 rubber on the rear and added a lower stress bar to reduce chassis flex. Now the rear of the car is completely predictable. I feel I can put the rear exactly where I want it with my right foot and no surprises. I am carrying higher speeds and some high 2nd gear turns are now moderate 3rd gear. So far so good.
The problem:
Now on downhill off camber turn in's and carousel turns she plows like nobody's business. I feel like I am crawling through these sections. Even if I really pitch the rear out the front just howls through. I am turning faster times. It just looks and feels really stupid when it plows.
Possible solutions:
A. Learn how to drive.
B. Lose those front tires cuz they're 4 yr old hockey pucks.
C. Add a front strut tower brace to balance front/rear chassis stiffness and precision.
D. Fine tune the alignment.
Anything I am missing here?? Your input is appreciated. The more track and Auto-X experience the better.
Old 05-17-2008, 06:49 PM   #2
Porscheectomy
How about dropping the front tire pressure a bit or a little softer front sway bay (or stiffer rear)?
Old 05-17-2008, 08:12 PM   #3
Track rat
Topless's Avatar
I did vary tire pressures to see if it would help. Started at 32 cold, tried 34 cold...no change, went to 29 cold... a little better. Both days were unusually cold at around 55 degrees F. Probably worst conditions for old front tires. It was difficult to get heat in the tires and the track was nearly always cold. About 3pm on the second day the sun came out and warmed the track. We saw a lot more grip but still had understeer in the suspect corners.
Old 05-17-2008, 09:20 PM   #4
Get new front tires, they just cant match up to your new rears. I used to have really cheap tires all around and the car acted like a snow plow. It sounds like you have enough experience to not be driver error.
Kyle Tarr
2000 Porsche Boxster
-Straight-piped from cats back
-MOMO race seats
-Schnell short shifter
-RJS Harness
-High flow intake
-Eibach lowering springs
-Bilstein sport shocks
kyle986driver is offline   Reply With Quote
Old 05-18-2008, 03:26 PM   #5
Track rat
Topless's Avatar
Ok, it seems the consensus is to put fresh tires on the front to match the grip in the rear. The old PS2's are just fine on public roads but protest too much when driven hard around the track.
So now the $$ question: Do I put a new set of PS2's the same size 225/45/17, upsize to a PS2 245/40/17 or go with a little stickier tire like the Advan Neova in 225/45/17? Any thoughts? Front wheels are 17x8 so both sizes would fit.
