Which one is the Radio Fuse?
I was told I may have a blown radio fuse. Is there a diagram to show me which one it is?
Thanks |
The paper fuse assignment list should be under the reverse side of of the cover for the fuse box.
If the diagram is not there go to renntech.org and search for fuse diagram. They have it there.
Check Fuses B2 (7.5A), D9(15A), E1(7.5A) These are Radio circuits. The actual Radio Fuse is located on the rear of the radio itself, so you need some 'radio keys' to pull it from the dash. The radio fuse is just another ATO/ATC fuse (10A). Also, be sure it's not the faceplate contacts. Pull faceplate and clean contacts on both the faceplate and head unit with a q-tip and alcohol, then make sure it's properly aligned when you reinstall it.
| All times are GMT -8. The time now is 12:06 PM. |
