Old 04-28-2008, 08:38 AM   #1
No power to ACC fuse and no cranking
Installed a AVIC D3, operated it fine before mounting after I'd done all the wiring, and had to leave town for a few days so I left it sitting still hooked up but not installed. Came home - doen't play and car won't start. Panel lights up but no crank at all. Battery is fine. ACC fuse blown. Replaced but still no crank, and no power to acc socket either. Using a DMM I find no 12VDC at the acc socket with the fuse removed. Like something big popped and even though it blew the fuse it took out something else? Would this stop the car from cranking? Seems mosre like some immobilizer feature, like maybe my key programming got erased or something. Even changed the ignition switch but no change in problem. Help?
Kevfra is offline   Reply With Quote
Old 04-28-2008, 01:33 PM   #2
Lil bastard's Avatar
Bad ignition switch is a possibility, could also be one of the high amperage fuses (aka Fusible Links), F4 - Ignition lock is one possibility. They're located under the dash in the passenger seat footwell under a sealed cover. Read lft to rht F1-F7. Pull F4 and test for continuity with your DMM.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 04-28-2008, 01:37 PM   #3
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Did you try to jump start the car? If that works then your Power wiring for the D3 is backwards.
http://i46.tinypic.com/2qx0rqs.jpg
2001 Boxster Artic Silver / Black Interior
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-Michilen PS Tires 225/40/18 & 285/30/18
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Pioneer Avic-F90BT Navigation
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Bose OEM Subwoofer & Midrange
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
