Old 03-11-2008, 07:13 PM   #1
How can I get rid of the amber in my front lights?
I've got the clear/red tails on the way. I've found some clear side markers on ebay, but how do I get rid of that orange triangle?
Nick
SinnerDC2 is offline   Reply With Quote
Old 03-11-2008, 07:22 PM   #2
You cant, You have to buy the newer clear halogens like I just di. or the pricier litronics.
1999 Boxster
Triple Black (Basalt metallic)
Silver Carbon Fiber Interior,De-Ambered,Euro LED Taillights, Eibach Pro Kit lowering springs,EuroTech 19" wheels/Kumho tires,Turbo spoiler,Clear halogens
Gemballa red face gauges ..(FOR SALE)
http://i28.tinypic.com/2zzlq29.jpg
986speedster is offline   Reply With Quote
Old 03-11-2008, 07:48 PM   #3
do i have to buy new lights? or can I just replace the amber part of my lights? I have a 2000 base
Old 03-11-2008, 08:11 PM   #4
There Is No Substitute.
rick3000's Avatar
The headlight is two parts: the headlight and the small corner triangle.
The triangle can be replaced in clear for about $40-60.
The actually headlight (which also has amber) must be completely replaced to eliminate the amber (about $900+ a set used). You can either replace that entire part with clear halogens, or lit.'s.
Some people have also, used black spray tint, and various other methods to cover the amber without replacing their headlights.
Old 03-12-2008, 05:46 AM   #5
You can paint over them with spray tint in whatever color you need. They can match your car color at a decent body shop and the light will still pass through. Or take a look at Gary in BR's lights
nola911 is offline   Reply With Quote
Old 03-12-2008, 06:18 AM   #6
There is a way to remove the INNER amber reflector from the newer clear headlights for a completely clear look, But it sounds like you have the earlier headlights were the amber is part of the lens itself. If this is correct, as others have mentioned, you cannot get rid of it without replacing the headlights.
http://www.renntech.org/forums/index.php?showtopic=178&hl=amberectomy
The above link has good DIY mod instructions as well as examples of both types (early & late) of headlights.
Aron in T.O. is offline   Reply With Quote
