Old 03-11-2008, 01:50 PM   #1
Bad Hub or Wheel Bearing?
How do you tell the difference between a bad rear wheel bearing and a bad rear hub? Also, how can I determine which side?
This evening I jacked the car up and tried to shake the wheels and neither would move......
I have been hearing the medium level "roar" a little while now, I assumed it was because of the balding Kuhmo's I had on the car but when I picked the car up from the tire shop, my tire guy said that when he test drove the car he hear the noise and he thinks its a bad wheel bearing (possibly driver side but he couldn't really determine which side it was) He then said it might be a bad rear hub.
Now that I have new brake pads, new tires, fresh oil, and a new battery, i'm ready to get this wheel bearing/hub taken care of so that I can enjoy the spring top down season.......
2001 Boxster
2014 Toyota Tundra
"Its Craptacular" - Bart Simpson 1997
joshua6060 is offline   Reply With Quote
Old 03-18-2008, 04:16 PM   #2
slogans7's Avatar
I've got it too. Sounds like I'm driving a large truck. It's probably a bad wheel bearing, based on the posts I've seen here. Do a search for "rear+noise" and you'll find a lot of information.
2002 Triple-Black Boxster S
slogans7 is offline   Reply With Quote
Old 03-18-2008, 05:03 PM   #3
You can often tell a bad wheel bearing with a forceful well placed shove. Kneel in front of the wheel. Place both hands on the wheel (at ten and two). Push in really hard. A bad wheel bearing will exhibit itself by a noticeable click-click. If that doesn't work, jack the car up so the wheel is off the ground and repeat your shove test.
Regards,
Alan
renzop is offline   Reply With Quote
