Old 02-01-2008, 08:49 AM   #1
Dead Battery = No Engine Block for negative cable
Hi, My 01 Boxster has been sitting up for about the last 6 weeks so when I go to start it and Battery is dead, I read a few post on here that said follow the basic steps for giving my car a jump, however the last part of the basic steps include touching the negative jumper cable to the engine block or frame. So what do I do with the negative cable since the engine is behind the front seats???? Can anyone tell me where to stick the negative jumper cable so that I can jump my car?
joshua6060 is offline   Reply With Quote
Old 02-01-2008, 09:09 AM   #2
On the negative battery terminal...................
Old 02-01-2008, 09:20 AM   #3
Every Battery Jump Instructions I have read tells you not to put the negative on the negative battery terminal........
"You usually want to avoid placing the Negative(-) cable directly on the dead battery to minimize the chance for explosions. "
"Attach the other end of that cable to the engine block of the car with the dead battery. Look for unpainted metal surfaces and be sure it will clear anything moving when the car starts. Do not attach the negative cable to the dead battery itself"
"Connect the other end of the negative cable to metal on the engine block on the car with the dead battery. Don't connect it to the dead battery, "
Old 02-01-2008, 09:27 AM   #4
Hi Josh,
No need to try to get the cable to the engine block. Since the battery is located in the front luggage compartment, just find a metal part of the car that is exposed (preferrably one that is attached to the frame--not onto the amplifier either) and hook it up there. You can find exposed hardware along the frame (if it's painted, just scratch off some of the paint---though, it shouldn't make too much of a difference).
BTW, there has been much discussion about jumping the battery of our cars due to the sensivity of our computer system and the possible expense that one might incur.
IMHO, if the battery is old and completely dead (interior / dash lights does not work) then maybe it's time for a new battery. (If you take this route, do not forget your radio code---usually found on a card that comes with your manual). Another alternative would be to use a trickle charger and the last alternative, IMHO, the jumper cables.
Good luck with that!
dcporsche99 is offline   Reply With Quote
Old 02-01-2008, 09:34 AM   #5
couple of options if you don't want to hook to the neg term....
- use a slow charger on it
- use a fast charge on it
- try to find some unpainted steel body surface to attach it to (i.e. bolt)
- use a cigarette lighter charger
- use a cigarette lighter jumper
- buy a new battery
Old 02-01-2008, 09:41 AM   #6
the dash bored lights all come on so i think the battery is probably still good.....
Old 02-01-2008, 09:46 AM   #7
Then, just use a trickle charger ( 6 amperes or less). I have a Schumacher brand that plugs into the wall (you can purchase this at any automotive shop)....as BB mentioned, there is also a cigarette trickle charger (I've only seen these online---like fleabay) available as well.
(Note: If I had to purchase a new one, I would go with the one that plugs into the wall and turns off automatically once the battery has been fully charged).
