Old 01-22-2008, 02:31 PM   #1
Proper 18" tire size for 10" rear wheels??
Hey there,
I ordered 18" Italian replicas (8" front/10" rear) for my summer tire set-up and installed winter tires on my factory 18s. I was planning on installing the factory rubber (265/40/18) on the new wheels, but my installer told me that those tires are not wide enough for the 10 inch rear rims. When I look at Tirerack, I don't see any 275 or 285 18s that are Porsche rated.
Need some help - thoughts anyone??
Thanks,
Steve
ktee is offline   Reply With Quote
Old 01-22-2008, 03:54 PM   #2
Originally Posted by ktee
Hey there,
Thanks,
Steve
I have 18" Carrera 3 wheels on my 07. The rears are 10" wide like yours. I'm using the 265/40ZR18 PS2s. The tires haven't fallen off wheels yet.
JackTs2K is offline   Reply With Quote
Old 01-22-2008, 04:00 PM   #3
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Ktee
Is this for a 986 or 987?
You can either run a 265/35/18 which WILL fit on a 10" wheel. The tire will just look a little bit stretched.
I personally run a 285/30/18 on my 10" rear wheels. This is also a factory Porsche tire size.
What is the offset of your wheels? Ultimately this will determin what size tire you can run.
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 01-22-2008, 05:21 PM   #4
The car is a 987 and the offset is 47. Will the 285/30/18 fit that offset?
Old 01-22-2008, 05:28 PM   #5
I thought it a bit funny.. Worry about "Porsche rated" tires on your "Italian replicas".
A 275 or 285 would be a preferred width for a 10" wide rim. Porsche doesn't have a prefered tire because they don't equip (base or option) a 10" rear wheel on the Boxster. Now, depending on any mods to the car, in particular the suspension, this is where you could have fitment problems. But, they should work ok.
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
Old 01-22-2008, 05:47 PM   #6
husker boxster's Avatar
I used 275/35/18s on the 10" 47mm rears on my old 01S. This size really filled out the wheel nicely. (BTW, the tires are for sale in the classifieds - shameless plug.) Your 265 will work but it may be a stretch for that wheel. There won't be much tire sidewall protection of the wheel lip. I went with 275/35 because there were more choices available in that size that were reasonably priced. There's quite a price jump when you go to 285/30, mostly because there are fewer manufacturers.
Also, according to the handy-dandy wheel offset calculator, going from a 9.5" 43mm wheel to a 10" 47mm wheel will move it inward by 10mm (approx 1/4"). That's a healthy move. Might want to see if there are going to be clearance issues. Some spacers may be required. On a 986 it's an 8mm move (9", 52 to 10", 47) and there are issues with the e-brake cable. Don't know what might be lurking on a 987.
Good luck and enjoy.
1989 928 S4 5 spd - black
