Old 01-03-2008, 07:26 PM   #1
SGR
Unhappy Help with oil leak !!!
Hello everyone,
I would like to say thanks to all of you for taking the time to look at my issue.
I have a 2000 Boxster tiptronic that developed a small oil leak (It is not the RMS)
It appears that it is coming from the rear right side axle. I looked a little closer today and it looks like engine oil.
My question is this:
Is the transmittion oil a different color or the same like the engine oil ?
Thans again,
Serge R
SGR is offline   Reply With Quote
Old 01-03-2008, 07:52 PM   #2
according to the bentley manual, the tip uses hypoid oil for the differential. this oil has a peculiar odor, but is thicker than engine oil. But it looks like engine oil. the tip also uses atf oil. the atf oil that I've seen is red, but I've never had a auto or tip gearbox before. good luck
brp987 is offline   Reply With Quote
Old 01-03-2008, 08:08 PM   #3
Check the Right side(passenger) for leaks either at the:
1.Spark Plug tube, 2. AOS tube, 3. Valve cover gasket
spine911 is offline   Reply With Quote
Old 01-03-2008, 08:11 PM   #4
Is it possible that the tiptronic's oil cooler could be leaking?
Old 01-03-2008, 08:39 PM   #5
SGR
Not the oil cooler. The valve cover is kind of wet but I can't see the connection since the heavy soiled area is around the rear axle
Serge R
Old 01-04-2008, 05:06 AM   #6
tboyer's Avatar
Cam cover gasket?
'06 Cayman 'S' - Sold (Sport Chrono, PASM, TPMS, 19' CAS Wheels, NAV)
'06 Cayenne - Sold
'01 Boxster 'S' - Sold
'00 Boxster - Sold
tboyer is offline   Reply With Quote
Old 01-04-2008, 08:49 AM   #7
have you changed your oil recently? it could be the oil filler tube. follow it from the right side trunk on down.
fatmike is offline   Reply With Quote
Old 01-04-2008, 09:21 AM   #8
Can't you just take it into the dealership for an estimate? Sounds like it should be addressed soon.
porsche986spyder is offline   Reply With Quote
Old 01-04-2008, 10:48 AM   #9
SGR
Oil was changed 8 mo ago. I took the car to an independent shop. It looks like the axle seal is leaking however he never heard of an rear axle seal leak.
It is a very slow leak that's why it is so hard to tell its origin.
If it wasn't for the occasional drip to the muffler I would have left it alone.
Old 01-04-2008, 01:04 PM   #10
Could a C.V. boot be leaking?
Old 01-04-2008, 06:43 PM   #11
Oil leaks originating either from the: 1. Spark Plug tube 2. AOS 3. Cam/Valve cover WILL seep, and eventually drip on the muffler
Old 01-04-2008, 06:46 PM   #12
CV boot grease is more like gunk than a liquid oil, so I don't think so.
1995 Silverado V8 - Green/Tan (FOR SALE)
2000 Boxster S - Ocean Blue/Graphite Grey
2002 GSXR750 - Blue/White
http://www.darkoven.com/sig.jpg
David N. is offline   Reply With Quote
Old 01-04-2008, 07:21 PM   #13
SGR
CV boot is tight. AOS has been replaced no leaks there.
I cleaned the affected area yesterday. I am going to put some miles on the car and then look around some more. Hopefully something will surface.
Keep you posted.
Old 01-04-2008, 07:46 PM   #14
I had an oil leak that found the exhaust.. turns out it was a failed "oil pressure switch". Located on the passenger side of the car. Saw the leak on the bottom. Saw the failed piece from looking down on the motor from the top.
Mine was a bit more worrysome because of course, with an increase in revs brought an increase in the leak. Eventually lots of smoke from the oil burning off on to the muffler/cats.
Let us know what you find out!
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
Old 01-09-2008, 01:54 PM   #15
SGR
Ok, here is the update as promised. After driving the vechicle for about 60 miles it looks like it is the axle area that is leaking. Not the CV boot. As far as I can tell it looks like it is coming from the differential shaft as it exits the casing. I am not sure if there is a seal or what in that area. I sure can't seem to find any posting anywhere regarding similar experience.
Anyone that worked in that area before willing to share tips I would greatly appreciate it
Cheers !
Old 01-21-2008, 04:17 PM   #16
SGR
Ok. Here is the update.
Car is fixed. My diagnosis was right on the money, leak was coming from the rear differential.
Rector Porsche come through. They did a great job. $700 for it.
Hector at the service department is the guy to talk to. Hector thanks again!
