Old 01-03-2008, 09:02 AM   #1
instructions on taking out the orange from headlights?
where can i find these?
on one headlight that i had the lens off i see how it can be taken off, but i dunno how to do it with the outter lense still attached.
any help is appreciated.
my cardomain/pictures page
Old 01-03-2008, 09:24 AM   #2
07 Carrera S Cab
Boxtaboy's Avatar
Here you go (Tool Pants documented it):
http://www.renntech.org/forums/index.php?showtopic=178&hl=amber
Old 01-03-2008, 09:32 AM   #3
I've seen it on this site before as well.
http://www.porschesite.com/index.php/topic,26.0.html
SRQ Boxster is offline   Reply With Quote
Old 01-03-2008, 09:50 AM   #4
after reading both i still dont get it...what do u do w the soldering iron? just make a hole?
Old 01-03-2008, 09:58 AM   #5
Go in thru the bulb hole. Use the soldering iron to break up/melt the amber plastic piece so you can pull it/them out thru the bulb hole.
Old 01-03-2008, 10:05 AM   #6
I've always wanted to do this mod but it sounds way to risky. One screw up and the lights are worthless. Wish someone could do it for me and warranty the work.
porsche986spyder is offline   Reply With Quote
Old 01-03-2008, 10:11 AM   #7
Maybe this one will help ya.
http://hverheyen.vssi-eda.com/box_pics/lights/index.html
Old 01-03-2008, 11:53 AM   #8
thx for the help guys.
i just did it...looks way better.
Old 01-03-2008, 12:21 PM   #9
I did it a few months ago and love it too. How are the reflectors? Mine got coated in a thin haze of plastic smoke (soldering iron probably too hot) but it came off with some isopropal alcohol and a q-tip.
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 01-03-2008, 12:22 PM   #10
Perfectlap's Avatar
yes that's an excellent mod. Proceed with the soldering iron carefully though...very easy to burn the sides of the plastic socket hole for the bulb.
Its a good idea to buy a short piece of metal tubing from Home Depot to sheath the soldering iron. Shop vac also comes in handy to suck out the broken bits of amber plastic that you miss with the needle nose pliers.
Old 01-03-2008, 02:15 PM   #11
i used 2 pliers and broke the pieces in 2...then since they are very flexible i just bent them in an oval kind of and pulled them out, so i didn't use the soldering iron at all.
no scratches and no haxing or anything...plus i bet even if you have scratches it wont affect anything since its smokes lenses and you cant see inside.
Old 01-03-2008, 03:57 PM   #12
I did this a while back, as well. Used the solder iron to intially deform the amber, then used the needle nose pliers for the balance. No harm whatsoever to my headlamps.
Old 01-03-2008, 05:15 PM   #13
i had tu run some errands so i snapped these 2 pics to show the difference, it looks much better
im happy now
Old 01-03-2008, 05:53 PM   #14
It does look a lot better. I got to do it soon, the amber(yellow) is making my front turn signal "Greenish" since I am using blue bulbs. Got to do it before I get pull over.
ichiro75 is offline   Reply With Quote
Old 01-03-2008, 06:28 PM   #15
You folks are still taking a hot soldering iron to a perfectly good set of expensive headlights, made of plastic, to get rid of an internal amber lense, that never bothered you....
I see links to my stuff and Henry's. My Boxstir "claim to fame" is to come up with the name "amberectomy." After I was banned from ppbb 7 years ago I registered on German and UK Boxster message boards.
Back then, on one of the German boards, there was a post about melting plastic with a soldering iron put into the headlight, or something like that. Since I do not read German I used a translator and could not figure out exactly what the Germans were doing. With the translator I could understand only about 1/3rd of the German words. And there were no pictures posted to shed any light on what they were doing with a soldering iron.
Then I met local Boxster owner Henry, who is Dutch, and Henry reads and speaks German, and figured out what the Germans were talking about. Then Henry did the operation on his own car. Then I introduced Henry to another local Boxster owner, Raman, who also wanted the operation. The pictures you see in the links are the ones I took of Dr. Henry doing the procedure on Raman's car.
The operations were a success, so I had to give it a name - amberectomy it was. Then the amberectomy procedure got picked up on the US Boxster boards.
All these years later Dr. Henry is still in practice. His last operation was a few months ago at a local work on cars days held at his house. This time the patient was a 996 owner, and the owner's back is in the picture. I told him not to look while Dr. Henry operated.
And that is the amberectomy history, if anyone cares. Prior to that I coined the term "cupholderectomy," but that is another story.
Old 01-03-2008, 08:22 PM   #16
That's a great story. Now get the translator widget. I have it on my Mac and it;s great for translating forein web sites.
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
Old 01-03-2008, 10:03 PM   #17
why did you get banned from ppbb?
