Old 11-28-2007, 11:23 AM   #1
Send a message via MSN to Gerardo de Kort
left radiator fan low speed failure
For awhile I've had this issue. My left radiator low speed fan does not kick in. Only the high speed mode works. My right side fan works fine. Both low and high speed.
Could this be a relay and if so... where is it? Pics, maybe?
The fuses are good.
Hope you guys can help!
THX!!
'98 Porsche Boxster 2.5 non US Spec
Mods: B&M short shifter, new shifter, new handbrake, new steeringwheel. K&N element filter. Zimmerman cross drilled rotors. Pagid Blue brack pads.
Ruf front bumper. Aftermarket side skirts.
Ruf 18" wheels with Michelin PS2s premounted and balanced.
Turbowerx Twin Turbo kit (self installed)
Ruf lowering springs.
Gerardo de Kort is offline   Reply With Quote
Old 11-28-2007, 12:44 PM   #2
Not a fuse. It's a resistor that is hardwired in by the fan, about the size of a cigar. I'll find a pic....
thread on RennTech: http://www.renntech.org/forums/index.php?showtopic=15680&hl=resister
pic courtesy of Loren over on RennTech
kabel
kabel is offline   Reply With Quote
Old 11-28-2007, 02:32 PM   #3
Thanks for the reply! Awesome!
Indeed I did notice this "resistor" in the past. It looked as if the wires had touched and shorted.
I'm gonna pull it out and see where I can find one.
Any suggestions? Is it compatible maybe with audi's or bmw?
Old 11-28-2007, 02:50 PM   #4
Anyone know what that Lip is for in that picture.. the lip held in by 3 bolts in the picture?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 11-28-2007, 03:43 PM   #5
I only know about this because my mechanic replaced one during my last visit (to replace the water pump). I'm not certain where you could get one, but a dealer or one of the several online parts vendors (i.e. Pelican Parts, Sunset Imports) would be a start. It is also referred to as a ballast resistor
CJ, I'm not sure what the name of that piece is but unless they have been broken off (like one of mine), you should have one on the leading edge of the front wheel wells. Little debris deflectors I'm guessing.
kabel
