Old 11-28-2007, 10:57 AM   #1
Will these wheels fit?
Hey guys, I know several of you have put these repro carrera wheels on. They are all over ebay and they all seem to be 18x8 in the front and 18x10 in the back. My question is will these fit without spacers/modifications? My concern is with the back wheels, since they are wider than stock. I don't want any rubbing issues going on. My car is not lowered. If they are not bolt on, do you know of carrera repros that are offered in a 18x9 inch size?
Old 11-28-2007, 12:28 PM   #2
Look just like the 18x10 a lot of members have, including myself. No mods, no spacers, and no rubbing from the wheels. I run a 265 without problem.
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 11-28-2007, 12:40 PM   #3
Thanks Tim, I was wondering because some Ebay vendors say they won't fit a boxster for some reason.
Old 11-28-2007, 12:43 PM   #4
In that case you should probably verify the offset to be safe. I ordered mine from Wheel Dynamics (by phone, not ebay). Mention 986forum and get free shipping.
Old 11-28-2007, 01:30 PM   #5
Adam, how are those rims different from the ones on your car now? They look the same.
porsche986spyder is offline   Reply With Quote
Old 11-28-2007, 02:14 PM   #6
They are the same. I want to buy a set and have them painted black since nobdy sells them that way. A guy with a white 911 turbo had black carreras on his and I fell for the look.
Old 11-28-2007, 04:49 PM   #7
Why not just have your current wheels painted black??
My stock turbo twists are 18x10 in the rear though. No problems at all with a 265.
yellowboxster01 is offline   Reply With Quote
Old 11-29-2007, 10:09 AM   #8
I want a spare set of wheels/tires for auto-cross. I'd also like to keep the original wheels original I guess. Thanks for the feedback guys.
Old 11-29-2007, 10:26 AM   #9
Stock turbo twists are 18x9 on a Boxster. If you have 18x10's, they're off of a Carrera, or they're replicas.
To the original poster, what is the offset on those 18x10 five spoke Carrera replicas? There are a couple different offsets for 911 (widebody and narrowbody) and that will determine if they will fit.
I've seen 18x10's with around a 65mm offset, which moves the wheel one inch closer to the rear strut than the stock 18x9 wheel. That may or may not fit, depending on the tire. You can fix it with a spacer.
I've also seen 18x10's with a really low offset, in the range of 40mm which moves the wheel out towards the fender by an inch. It fits, but in my opinion looks kind of silly.
If you tell me the offset I can tell you if they're likely to fit.
John V is offline   Reply With Quote
Old 11-29-2007, 10:36 AM   #10
Here is the info on the site.
18x8 inch 18x10 inch, 5x130mm 50/47mm
Silver Wheels
It looks like the offset is 47mm for the rear. This place says they will fit the boxster so all should be fine. 47mm sounds good to me as I would like the wheels to be pushed out and more flush with the fenders.
http://www.lakeshorewheelandtire.com/specials/porsche-boxster.shtml#18inch
Old 11-29-2007, 10:53 AM   #11
Silver Wheels
Size and offsets are identical to my wheels and I'm sure it is the same "Made in Italy" supplier for Lakeshore, Wheel Dynamics, and the rest.
Old 11-29-2007, 12:10 PM   #12
Silver Wheels
47 in the rear is about perfect. .7" closer to the fender than stock and .3" closer to the strut. Should be able to fit a 285 back there with that offset. Anything less than 47 in the rear pushes the wheels too far out and looks kind of funny - makes the back end look jacked up unless the car has been lowered.
50 is the same front offset as the stock 7.5" wheels, meaning the extra half inch of wheel width is split equally between the inside and outside of the rim.
JV
