Old 11-26-2007, 01:35 PM   #1
Camber adjustment bolt
Has anyone seen or used these at adjust camber??
http://www.allsprings.com/catalog/triple-c-camber-bolts.htm
99 TWIN TURBO Boxster 175k+ miles
Growing up the car magazines said how amazing Porsches are. Was I brainwashed? Somehow...I doubt it.
http://www.pcars.us/albums/10641_porsche_cars.jpg
Gary in BR is offline   Reply With Quote
Old 11-26-2007, 01:53 PM   #2
Send a message via MSN to CJ_Boxster
Not me but i'd be interested if someone here did use them and was able to get more positive camber with them.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 11-26-2007, 01:59 PM   #3
They are pretty cheap. I emailed the dealer to see if they carry them for the Boxster. If they do I will try them.
I am having all kinds of suspension fun this week.
Adjustable toe links and new rears going on Wed.
If I can get the camber bolt overnighted they will go on Wed also.
Old 11-26-2007, 02:09 PM   #4
Very nice!
Just to be certain, Did you have the issue of not having enough adjustment to correct the "too much Negative camber" issue?
Carlos J Cazares
Old 11-26-2007, 02:26 PM   #5
My issue was too much negative camber, and too much inside toe.
I found out that the bolts will not work with our cars.
From what I have learned the adjustable toe arms will correct my toe and give me more room to correct my camber.
Old 11-26-2007, 02:32 PM   #6
Ah, my issue is too much negative on the drivers side front, even with the camber bolts pulled all the way to the outside I'm barely 0.01 degrees within acceptible range.
Carlos J Cazares
Old 11-26-2007, 02:36 PM   #7
Most coilovers have camber adjustment for the front. Its an expensive fix but it is a fix.
