Old 11-26-2007, 08:33 PM   #1
Red face Airbag Light -- Indicating?
I had to go into the RHS door to adjust the window glass forward. In doing so I had to remove the air bag which required disconnecting the -ve terminal on the battery. I also couldn't at first see how to do disconnect the yellow connector for the airbag and in trying I took a purple cover off connector before finding the simple way.( Is this cover on the connector the short circuit spring? If so, I read that it should not be removed but don't understand why.)
Anyway I put everything back OK but the "airbag light " stays on !
I thought the conection to the airbag may not have been made properly but on checking it was OK and there is a voltage at the terminal albeit a fluctuating one.
I may have turned the power on with the airbag disconnected so would this register as a fault that has to be cleared or have I goofed elsewhere?
Chees,
Glenn
insatiable is offline   Reply With Quote
Old 11-26-2007, 08:42 PM   #2
If the ignition is turned on with an air bag disconnected then you will get the light.
Tool Pants is offline   Reply With Quote
Old 11-26-2007, 09:00 PM   #3
Wow that was an "express" reply -- Thanks!
Does that mean I have to go to a Dealership to have it cleared?
Glenn
Old 11-26-2007, 09:09 PM   #4
You need a PST2 or PIWIS or Durametric to turn it off.
We started a list of people who have this but nothing yet for Australia.
Old 11-27-2007, 12:53 PM   #5
I guess it will have to wait till the next service or I'm visiting Sydney as the nearest dealership is 400 Kms. away.
Thanks again I really appreciate your help.
Glenn
