Old 11-19-2007, 07:48 AM   #1
Need Help with Part ID & Function
See below:
The part in question is the rubber hose that's leaking fluid in the photo. It's located in the engine compartment, underneath the car, on the passenger side.
Is fixing this simple or does it require major disassembly?
Paul B. Anders / Phoenix, AZ
1970 Porsche 914 / 2003 Porsche Boxster / 2009 Honda Fit Sport Auto
pbanders is offline   Reply With Quote
Old 11-20-2007, 11:27 AM   #2
Bump.
C'mon, one of you guru's out there must know what this is. The car has Tip, the leak is orange colored fluid, oily. Doesn't look or feel like motor oil to me. Tranny fluid? Power steering?
Old 11-20-2007, 04:13 PM   #3
really hard to tell the orientation of this but it appears to me that it might be the bleeder from your clutch. I don't know about the orange color of the fluid though. I thought Porsche used ATE gold or something similar. I guess it might turn orange (ey) if it is old or burnt. Have you had your brake fluid changed recently? Check the level and color of your brake fluid and see if it matches up or if the level is low. Is this an active drip (fluid on the ground) or just residue that you noticed?
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
Old 11-20-2007, 05:08 PM   #4
Franco's Avatar
"The car has Tip"
I think his car has an Automatic transmission, sorry I have no Idea
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
Old 11-20-2007, 05:27 PM   #5
Right. Guess I should have read it a little closer. Maybe someone with a Tip and a Bentley can figure it out. If no one here can I am sure someone over at renntech would know.
'03 Midnight Blue
'69 911 Black
Cancer Survivor
Old 11-24-2007, 07:25 AM   #6
I've got a Bentley, looked through every pic I could find and couldn't ID it. It goes back to the dealer on Monday - this leak appeared after they did the RMS, perhaps due to disconnection/reconnection. It's a clear and clean orange fluid, doesn't appear to be oil. My guess is that it is either ATF fluid or from the power steering.
