Old 11-17-2007, 07:06 PM   #1
Door squeak
Hey all, got another squeak that's annoying the heck out of me. It's in the door rubber, towards the top near the handle. It's basically the rubber that's on the car body that makes contact with the door and seals it I guess.
It's the rubber right below the cheesy seatbelt pad (Not my car)
The rubber has worn and gotten shiny and slick, and I guess the door tends to squeak now as it vibrates against it on rough roads. I can remove the problem by sticking a towel in between and closing the door on it, not a very permanent (or sightly) solution tho.
Anyone know of any really good rubber conditioners, or maybe suggest something I can stick maybe on top of it to help eliminate the sound?
-David
1995 Silverado V8 - Green/Tan (FOR SALE)
2000 Boxster S - Ocean Blue/Graphite Grey
2002 GSXR750 - Blue/White
http://www.darkoven.com/sig.jpg
David N. is offline   Reply With Quote
Old 11-18-2007, 05:10 AM   #2
good ones to use/try are 303 Aerospace Protectant or Gummi Pfledge.
Old 11-18-2007, 08:05 AM   #3
Dupont Krytox GPL 205 weatherstrip lubricant, pricey, but it works.
Patrick
Old 11-18-2007, 08:13 AM   #4
There Is No Substitute.
rick3000's Avatar
It sounds more to me, that the problem is that, the door not closing properly and is moving while you drive. The door shouldn't be moving at all. Check the latch on the body of the car, maybe it has come loose.
Old 11-18-2007, 06:20 PM   #5
rick3000 - I was gonna suggest that too but assumed the archives might have already been searched...
Just in case, here's a thread about remedying door sqeaks (go to the bottom as the top is about a ticking noise over shoulder).
Ticking noise coming from right behind my left shoulder
