-   -   Some lucky bad luck (http://986forum.com/forums/boxster-general-discussions/14171-some-lucky-bad-luck.html)
derb 11-13-2007 06:01 PM
Some lucky bad luck
I discovered my spare tire was flat the other week and I couldn't inflate it because my cheap eBay special compressor wouldn't go past 10 psi. I then completely forget that the spare was flat. Fast forward to tonight. I back out of my driveway and hear a thump-thump sound. What the... I pull back into the garage and find the right rear tire very flat.
Looks like a piece of metal in the tread. I'm hoping it can be plugged/patched to get me thru the wiinter. The tread depth is close to the wear bar and I had planned on deferring the cost until the spring.
Bad luck- flat tire.
More bad luck- spare tire is flat.
Good luck- you are in your garage.
Check your spare tire once in a while. Not all flat tires happen in your garage.
Regards,
derb
blkboxster 11-13-2007 06:07 PM
That sucks, hopefully you wont need to buy a new tire
:cheers:
bmussatti 11-13-2007 06:08 PM
Hey Derb, I checked my spare....and I still DON'T HAVE ONE!! :)
I am sure someday the air compressor and fix-a-flat that Porsche gives us 987 owners will be completely usless the day I need it most! :mad:
rick3000 11-13-2007 06:13 PM
I agree check the spare often. They should be inflated to 60psi (for the lucky 986 owners :D ) I checked mine recently before a trip it felt inflated but was only at 15psi.
blkboxster 11-13-2007 06:14 PM
Oh, thats cool, the 987's Dont have a spare, never knew that, what happens if you tires blows..... i dont think fix a flat will help much :eek: , But i bet it saves some weight thou.
:cheers:
bmussatti 11-13-2007 06:21 PM
:cheers:
We call 1-800-767-7243!!! Roadside assistance. Got it on speed dial in my cell phone. And I keep a protein bar in the car for the 6 hour wait! :)
Just before the Tail of the Dragon trip (2,000 miles total), I bought a pair of needle nose pliers that has a side cutter jaw and those sticky fibrous emergency tire plugs. I figured this would at least help me limp along to a safer/better location in an emergency.
JCL12 11-13-2007 07:13 PM
Hey all - is it possible to order spare tires with new boxsters? I much prefer having a spare, even at the sacrifice of trunk space. If I stick with Pcars over time, I will be SOL after the 986.
pteam 11-13-2007 07:50 PM
Just order a spare tire from online.
bmussatti 11-13-2007 07:51 PM
JCL12, there is no place to put it.
