Old 11-12-2007, 10:39 AM   #1
Question Litronics Problem
I installed my litronics headlights some time ago on my 02 Boxster S. Used instructions on the Pelican Parts Board.
I had to connect the light's white wire to the black & while wire in the car instead of the solid white wire (Porsche Instructions), but now my left high beam does not work.
Any thoughts were the problem could be?
Thanks everyone.
JFERRhttp:
Only problem with a Porsche is the traffic.
JFERR is offline   Reply With Quote
Old 11-12-2007, 11:11 AM   #2
Did they work fine until recently?
There are 3 wires from the control unit harness. What did you hook up the white wire to? What was the color of the connector that you hooked up the white wire to?
Tool Pants is offline   Reply With Quote
Old 11-12-2007, 06:20 PM   #3
The left high beam never worked. Suncoast sent me a replacement bulb, but that didn't work either. I put back the original head light and that high beam didn't work either.
I connected the white wire from the control unit to the black & white wire in the car's harness. It is the only harness in the front of the car and it's located by the brake booster.
JFERRhttp:
