987 FM Modulator
after months of snap crackle pop reception, and also influenced by the broken plug on my iTrip....I finally threw in the towel and had the FM modualtor I received as a gift installed....bought and installed at best buy....
well here is the problem....the snap was there as was the crakle....my FM reception went to hell and the AM died.....I was getting 2 stations on the same frequeny.... took it back and I am now told the modulator I bought was incompatible with my radio and they found one that works better.....the Harmon Kardon plg n play or whatever it is called..... so does anyone have any insight on this? they want 120 for the unit and 120 for the install...this is just getting a lot more pricy than I orignally planned..... |
super,
I have the old version of this and it works great : http://www.newertech.com/products/trafficjamz.php For $35 it might be worth a try... Also, they are located in Woodstock. You may want to give them a call and see if they would let you try it to see if it would work ? Nick |
| All times are GMT -8. The time now is 09:50 PM. |
