Old 10-29-2007, 06:43 PM   #1
Coolant Odor
My 2002 Boxter has the odor of coolant after shutdown. Am not seeing any on the floor. Not in the rear trunk and mat is not wet there. Maybe a radiator cap?
Any ideas appreciated.
Thanks.
Dave Hathaway
Oklahoma City
dhathaway is offline   Reply With Quote
Old 10-29-2007, 06:50 PM   #2
My 99 is doing that too. It's usually dry, but sometimes spits a little out underneath the reservoir area. Hmmm...
PhxRealtor is offline   Reply With Quote
Old 10-29-2007, 06:55 PM   #3
HammerESQ's Avatar
If it gets stronger when you open the trunk then you're looking at a coolant tank. It's an easy repair, but getting to all the lines is a real pain. There is a better write up here: http://986forum.com/forums/newreply.php?do=newreply&noquote=1&p=122365
Hope this helps..
-Eric
HammerESQ is offline   Reply With Quote
Old 10-30-2007, 02:20 PM   #4
You probably have a leak on the front of the engine that is dripping on the cover and never reaching the ground. Try sticking your fingers on top of the cover, just about the center of the engine and see if you can feel any crusty stuff up there from evaporated coolant (or drop the cover and see if it's covered with dried stuff)...
efahl is offline   Reply With Quote
Old 10-30-2007, 02:24 PM   #5
Send a message via AIM to blinkwatt
Hope this helps..
-Eric
You posted a link as if you replying to this thread.....
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 11-02-2007, 08:50 AM   #6
HammerESQ's Avatar
Hah, so I did.. Thanks for calling me out on that Blinkwatt..
Here's the real link: http://www.dietersmotorsports.com/tech/tech9-03-2003.htm
It's also important to note that you won't see a wet spot in the carpet per-se. The rear carpet sits up on a platform of sorts, and the coolant typically drips underneath that.
Good luck!
-Eric
Old 11-02-2007, 04:03 PM   #7
Just bought my coolant tank today! With new cap was $260.00 oem.
Seems like as soon as the weather cooled down, a bunch of us here found leaks.
Porsche gremlins!
Joe DiMonte
2001 Boxster S
Triple Black
AUDIOGUY is offline   Reply With Quote
