10-07-2007, 07:28 PM
#1
Are all the hardtop for boxster same07-04?
Hi looking to buy used hartop for my 03. Do i need specail clamps,bolts? or does it just click into place the same as the softtop connections? thxs
10-08-2007, 12:56 AM
#2
At the front they are the same. At the rear you need a special fitting kit installed. They are not expensive, over here you can get them for 40 GBP, I guess they will be $75-100 from your local Porsche dealer.
10-08-2007, 06:43 AM
#3
There Is No Substitute.
You need to install spinlocks in the back, on each side. Sunset Imports is the cheapest I found at about $65. You need the two bolts and right and left spinlocks. If you call them they should now what you're talking about.
10-08-2007, 11:24 AM
#4
Here are some instructions for installing the spin locks:
http://www.renntech.org/forums/index.php?showtopic=10440
I think you will have to register on RennTech to view the topic.
Good luck finding and installing your hard top.
10-08-2007, 12:23 PM
#5
hello, thanks again for replies.
10-08-2007, 12:52 PM
#6
I had the black plastic caps on mine, but I had to install spin locks.
Lock at the sketches in this technical bulletin:
http://www.renntech.org/forums/index.php?act=attach&type=post&id=5526
Basically, if you see a round empty hole when you remove the black plastic caps, you don't have the spin locks.
10-08-2007, 03:25 PM
#7
The hardtops will not fit all years. The tops changed with the model changes. 986 needs that series top, different from a 987.
10-08-2007, 04:56 PM
#8
If anyone with a hard top no longer wants their black plastic caps, I would like them.
PM me if you've got them lying around in your tool box gathering dust!
